February 05, 2026, 08:10:56 AM *
Author Topic: electric fuel valve  (Read 1452 times)
groundpounder01
« on: June 26, 2012, 08:02:18 AM »
Those of you who have the electric fuel shutoff, where did you pick up the hot wire to control it? I know there is several different wires, just wondering if there was a common location everyone uses.
Chattanooga Mark
« Reply #1 on: June 26, 2012, 08:43:45 AM »
I grounded my Dan Marc to the engine using one of the mounting points left vacant when I desmogged and used the hot lead of the Accessory leads on my Interstate for power when the key is on. I used MarkT's excellent instructions found here: http://horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
All the best,
Mark
www.bikersforchrist.org
X Ring
VRCC #27389, VRCCDS #204
« Reply #2 on: June 26, 2012, 08:53:33 AM »
I tapped the power lead for the rear coil.  That way if the engine shuts off the the solenoid closes.
Marty
BigMac (SoCal)
Moreno Valley, California
« Reply #3 on: June 26, 2012, 06:26:06 PM »
Ditto on what Marty said. That's where I hooked up mine.
Dave
BonS
Blue Springs, MO
« Reply #4 on: June 26, 2012, 07:03:36 PM »
I had some occasional misfiring at high rpm's when I had mine on a coil so I moved it to the accessory terminal and all is well.
« Reply #5 on: June 26, 2012, 07:50:55 PM »
I also used my accessory circuit.  Smiley
My rides:
« Reply #6 on: June 27, 2012, 01:21:49 AM »
Wired in a relay with diode as a latch to power the dan-marc, and triggered it with a hidden pushbutton. Power to the latch is from the kill switch.  Wired in a LED which points at some of the chrome so I can see it's reflection, in parallel with the solenoid power, so I can see if I have a powered fuel solenoid.  All of this makes it anti-hijack.  If the ignition is switched off, or the kill switch is hit, the dan-marc goes off.  Now if you get the bike started and don't hit the hidden pushbutton, you will run out of gas in less than a mile.  Doesn't take long to get in the habit of hitting the pushbutton right after starting it.
« Last Edit: June 27, 2012, 01:35:20 AM by MarkT » Logged
