February 05, 2026, 08:10:34 AM *
Author Topic: Removing rear wheel with belly tank installed  (Read 1536 times)
flatsixrider
2000 Standard
Greenville, SC
« on: June 26, 2012, 11:12:07 AM »
I need a new rear skin and want to remove the wheel myself for a dealer install of the tire.  Can I do this with the belly tank installed?  if so, how?  Any good articles written on this topic?
thanks!
Sometimes the appropriate response to reality is to go insane.
Farther
Quimper Peninsula, WA
« Reply #1 on: June 26, 2012, 11:26:11 AM »
No need to remove the belly tank.  See R&M's site for details:  http://www.rmworksinc.com/Lift.html
~Farther
flatsixrider
2000 Standard
Greenville, SC
« Reply #2 on: June 26, 2012, 11:42:03 AM »
Thx.  I know I can lift it, but will I be able to remove the wheel with the limited downward travel of the swing arm with the belly tank in place?
« Reply #3 on: June 26, 2012, 11:48:48 AM »
I just looked at the door chock picture, that's pretty cool, a belly tank is also
a sort of stay-on-the-bike adapter...
I don't have a belly tank, so I can only imagine what's involved... if you can't
lower the swingarm enough to do what you want, would taking the rear fender
section off help? I always take my rear fender section off when I change tires.
There's a little wiring connector for the tail light that you have to deal with, but
it is pretty simple...
X Ring
VRCC #27389, VRCCDS #204
« Reply #4 on: June 26, 2012, 12:47:22 PM »
Yes you will.  You need to unbolt the shocks then raise the wheel in the fender so you can remove the axle over the exhaust.
Marty
bentwrench
Philadelphia,Pa.
« Reply #5 on: June 26, 2012, 04:00:31 PM »
Yep,what Marty said works with or with out a belly tank.
flatsixrider
2000 Standard
Greenville, SC
« Reply #6 on: June 27, 2012, 05:41:03 AM »
Marty
great, thx!
X Ring
« Reply #7 on: June 27, 2012, 02:11:49 PM »
Marty
great, thx!
You are welcome sir!
Marty
