February 05, 2026, 08:11:04 AM *
Author Topic: VACUUM GAUGES  (Read 2565 times)
pocobubba
Pocomoke , Md
« on: June 26, 2012, 05:33:53 PM »
There is a set of 6 gauges on AMAZON described  as carb tune gauges for CBX 1000's  $88.50
tank_post142
south florida
« Reply #1 on: June 26, 2012, 05:52:43 PM »
http://www.amazon.com/Carburetor-Synchronizer-Gauge-Honda-CBX1000/dp/B004MSG262/ref=sr_1_15?s=automotive&ie=UTF8&qid=1340758322&sr=1-15&keywords=vacuum+gauges+6
I got a rock Sad
VRCCDS0246
« Reply #2 on: June 26, 2012, 06:58:02 PM »
dont waste the money on 6 guages.  You only need one guage........You check #3 and set all the rest to that reading one by one.  That way the error between six individual guages is iliminated.............a digital guage is even better...I forget the name of the unit but its still one guage that you move to each cylinder one at a time.....much better result that way
« Reply #3 on: June 26, 2012, 08:30:56 PM »
+1 Chris! My latest synchrinization was accomplished with the gauge posted below.
http://www.oreillyauto.com/site/c/detail/EQU1/3620/N1745.oap?ck=Search_N1745_-1_-1&categoryRedirect=N1745&pt=N1745&ppt=C0103
I used to use a Motion Pro sync pro, but that instrument will play second fiddle to this new 4" gauge from now on. As some others here, I created a series a tubing attached to various carbs that culminatied into a manifold. I would then cycle through the cylinders by releasing a pair of forceps pinched on the line that allowed airflow, make my readings, adjustments, etc. to approximate the reading from number 3. By the time I went through all cylinders for the fourth time, all readings were nearly identical to number 3.
« Last Edit: June 27, 2012, 04:44:50 AM by salty1 » Logged
My rides:
sugerbear
wentzville mo
« Reply #4 on: June 26, 2012, 11:01:04 PM »
i have a 4 gauge set. as one is adjusted the others will move also. greatly speeds up the sync.
and as for difference in gauges, i checked mine by attaching all of them to one source(mity vac). each gauge is adjustable. set them and you done.
but then i'm not the professional..........
LinnB
VRCC #25552
Arnold, MO
« Reply #5 on: June 27, 2012, 07:33:39 AM »
Would you be able to post a picture of your set up with the tubing attached to the manifold?  I've always wanted to learn how to do my own syncing and this would be a great start.
« Last Edit: June 27, 2012, 10:04:58 AM by LinnB » Logged
gordorad
Washington, MO
« Reply #6 on: June 27, 2012, 08:24:29 AM »
And it works great!!
Support the Arts!!    www.gordonradfordphotography.com
« Reply #7 on: June 28, 2012, 07:30:48 AM »
LinnB my system is all put away at this time, but is very similar to other posts that have been made at this site. Sorry!  Undecided
My rides:
LinnB
VRCC #25552
Arnold, MO
« Reply #8 on: June 28, 2012, 08:00:05 AM »
No problem at all   Smiley     I'll do some research on the other posts and see what I can come up with.
larswlvs
my littlest riding partner
Akron,Ohio
« Reply #9 on: June 28, 2012, 10:00:45 AM »
twinmax  is the way to go Smiley
If guns kill people where are mine hiding the bodies
LinnB
VRCC #25552
Arnold, MO
« Reply #10 on: June 28, 2012, 01:16:14 PM »
I see on their website something about a 5mm and 6mm adapter.  What do our Valkyries need?
Thanks.
« Reply #11 on: June 28, 2012, 01:43:46 PM »
The vacuum ports are already in place on the carb intake tubes of your Valk. Usually other Hondas I've owned had vacuum ports that required a 5mm adapters.
My rides:
Ken Tarver
North Mississippi
« Reply #12 on: June 28, 2012, 02:00:03 PM »
pocobubba,
they are the same gauge as sold at Harbor Freight. But sold individually. I bought 6; 1 of them did not read the same as the other 5 when checked on #3 cyl. So took it back for an exchange then made my set-up.
Brian
Monroe, NC
« Reply #13 on: June 28, 2012, 06:27:50 PM »
LinnB, go to the shop talk section here. This is where I received the info needed and gives you a good idea for making your own, others on here have gone to a pet store that sells fish tanks and accessories to purchase valves, fittings and tubing for their manifolds.
« Reply #14 on: June 29, 2012, 01:20:55 PM »
+1 !  cooldude
Brian
Monroe, NC
« Reply #15 on: June 29, 2012, 07:53:32 PM »
+1 !  cooldude
I just saw this last week on flyer that was stuck in the box with an order. Started thinking about putting it up on this site to see if anyone has used this device and would mind commenting on it?
