August 17, 2025, 02:00:04 AM *
Author Topic: Strange noise/vibration at idle in neutral?  (Read 1763 times)
DLSSOJC
« on: June 27, 2012, 06:47:45 PM »
Today I noticed for the first time a low grinding/rattling/vibration noise when my Interstate with 23K miles  is sitting at idle in neutral. You can even feel the low vibration in the bars. When you pull the clutch lever in, it totally stops and vibration goes away. Let it out and it starts again. This is the first time I have ever noticed this before. Anybody have this happen to them or know what this might be?
Thanks.
« Reply #1 on: June 27, 2012, 08:18:57 PM »
The hydraulic slave cylinder has a push pin to depress and release pressure on the clutch. This pin has caused some issues like you describe. Remove the slave cylinder and pull the pin out. Clean and lube with waterproof grease. Reinstall and see if that helps.
Kingbee
VRCC# 576
Northern Illinois
« Reply #2 on: June 27, 2012, 09:36:34 PM »
Nothing to be alarmed about.  It's just the gears spinning in neutral when you let the clutch out.
1999 Interstate
2000 Interstate
2004 Rune
CASABROKER
« Reply #3 on: June 27, 2012, 10:23:02 PM »
+1 spinning gears, these things make lots of strange noises.
Chattanooga Mark
« Reply #4 on: June 28, 2012, 05:52:23 AM »
Great question and responses. Sometimes I notice the same thing. More so in really hot weather.
Thank You,
Mark
www.bikersforchrist.org
DLSSOJC
« Reply #5 on: June 28, 2012, 06:37:35 AM »
Thank You,
Mark
We have been running 100+ degree days where I live and coincidently that is when I noticed it.
bludragon
Montreal, Quebec, Canada
« Reply #6 on: July 08, 2012, 06:11:14 PM »
Mine does this when bike is running for long periods of time and is hot
Former BMW Guy
Aut viam inveniam aut faciam.
Apple Valley, MN
« Reply #7 on: July 08, 2012, 07:28:37 PM »
Try changing the oil.....brand and viscosity.
JP
Motorcycling is not, of itself, inherently dangerous.
It is however, extremely unforgiving of: inattention, ignorance, incompetence or stupidity.
olddog1946
Moses Lake, Wa
« Reply #8 on: July 09, 2012, 11:01:49 AM »
Normal, normal,normal.............................
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
