February 05, 2026, 08:09:46 AM *
Author Topic: Mityvac well worth it!  (Read 1513 times)
DLSSOJC
« on: June 28, 2012, 05:27:27 PM »
I started having trouble with front brake calipers sticking on my Interstate, so I took them apart and cleaned everything real well and reinstalled. I went to bleed the brakes, and they would not respond at all to bleeding them the traditional way. I have bled the brakes on cars and some of my Harley bikes in the past with no real issues, but these were not working at all, and apparently had a lot of air in the lines. I went and bought a Mityvac kit with the hand pump and pressure gauge, and it was a miracle worker. Worked perfectly and only took a few minutes, and was worth its weight in gold! I will never bleed brakes again without it. If you don't have one and are going to take calipers apart or flush and put new brake fluid in, it is the only way to go IMO.  Smiley
« Reply #1 on: June 28, 2012, 05:29:13 PM »
+ a lot. cooldude RIDE SAFE.
« Reply #2 on: June 28, 2012, 06:02:35 PM »
Mity-Vac is a good little critter to have.. Its good for checking a multitude of things.. i don't happen to use them for brake bleeding,, but,, its good to have to the box collecting dust until its needed..
shortleg
maryland
« Reply #3 on: June 29, 2012, 06:08:59 AM »
   Also good for checking your fuel valve
 to see if it holds vacuum.
          Shortleg[Dave]..
whitestroke
San Pedro, Ca.
« Reply #4 on: July 01, 2012, 06:17:33 PM »
Are you using the Mityvac that pumps the fluid up from the calipers?  Have heard it's better since air naturally rises.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
DLSSOJC
« Reply #5 on: July 01, 2012, 07:10:25 PM »
The one I bought just attaches at the caliper and creates a vacuum and sucks the air and fluid out of the lines and the mastercylinder. Works like a charm!
