February 05, 2026, 11:43:25 AM *
Author Topic: Batwing/Headlight Question  (Read 1900 times)
Bob E.
Canonsburg, PA
« on: June 28, 2012, 07:30:07 PM »
I'm in the process of installing a HD Street Glide Batwing on my Valk.  As anyone who has done this and used the Valk headlight knows, you need to trim the batwing around the headlight housing.  So, how much of a gap around the headlight housing do I need? Right now, I have it as a snug fit, just touching all around.  But I'm worried about them vibrating against each other and making noise, not to mention scuffing the paint and chrome.  So I'm thinking I need to open it up a bit more, but how much?  1/16"?  1/8"?  More?
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #1 on: June 29, 2012, 03:50:07 AM »
My OEM Honda shield is about 1/4".
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
quexpress
Montreal, Québec, Canada
« Reply #2 on: June 29, 2012, 05:10:59 AM »
I placed mine snug on the headlight ... and then added a rubber strip on the fairing's headlight opening. It's been setup this way for approximately 8 or 9 years.  Smiley
I still have a full deck.
I just shuffle slower ...
flatsixrider
2000 Standard
Greenville, SC
« Reply #3 on: June 29, 2012, 07:48:52 AM »
I've had mine mounted within 1/8 inch all around for 6 -7 years with no issues at all. As long as it is solidly mounted and doesn't move you should be fine.  I do like the idea of a rubber strip around the opening.
Sometimes the appropriate response to reality is to go insane.
Brian
Monroe, NC
« Reply #4 on: June 29, 2012, 07:58:55 PM »
What brand of lower air deflectors do you have attached to the fork tubes? Do you like them?
« Reply #5 on: June 30, 2012, 11:48:01 AM »
Mines about a 1/8" and i used foam weather striping.
flatsixrider
2000 Standard
Greenville, SC
« Reply #6 on: July 25, 2012, 01:39:15 PM »
I believe they are from Memphis Shades.
