February 05, 2026, 08:11:02 AM
temperature indicator light
Topic: temperature indicator light (Read 1297 times)
baffled
June 28, 2012, 08:42:01 PM »
98 standard;temp indicator light quit working.does not come on when key is turned on.can anyone point me in the right direction.all pointers,tips & info greatly appreciated. thanks
jer0177
VRCC 32975
Pittsburgh, PA
Re: temperature indicator light
June 28, 2012, 10:02:28 PM »
This (from the shoptalk) shows you how your tach looks when disassembled:
The bulb part number is listed here:
http://www.rattlebars.com/valkfaq/schematics/rpage11.html
June 29, 2012, 03:48:51 AM »
The temperature light is only on when the bike overheats, it does not normally come on when you turn on the key. Hoser
shooter64
June 29, 2012, 04:00:44 AM »
Quote from: Hoser on June 29, 2012, 03:48:51 AM
Thanks, I meant to ask about that. The oil light comes on and the stand light, if it is down, but not the temp light.
Columbia, S.C.
June 29, 2012, 06:20:50 AM »
Your post indicates that the light use to come on with the key.. Huumm, regardless,, Hoser is right..
michaelyoung254
Huntsville, Texas
June 29, 2012, 06:57:44 AM »
If you're want to check to see if the indicator light is working, you should be able to disconnect the temperature sensor at the sensor, and then short the temperature lead to ground. Grounding the lead should cause the indicator light to come on.
1998 Standard - Pearl Sedona Red & Ivory Cream
indybobm
Franklin, Indiana VRCC # 5258
Reply #6 on:
June 29, 2012, 07:05:26 AM »
I thought the service manual says that it will come on for one or two seconds when the key is turned on. There is a good diagnostic checklist on case it does not come on. It might be 97, 98 only.
So many roads, so little time
VRCC # 5258
