August 17, 2025, 05:43:03 AM *
Author Topic: rear wheel dampers  (Read 3629 times)
baffled
« on: June 29, 2012, 11:03:13 PM »
noticed small specks of rubber on rear wheel.ordered damper set 06410 mbh ooo from cheap cycle parts just to find out they are on back order.no time frame yet.sure dont want to ruin rear wheel. is there aftermarket dampers available??PLEASE HELP: THANKS
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #1 on: June 30, 2012, 04:05:54 AM »
Baffled,
There were aftermarket available, I believe those sources have dried up. I have used both and currently have the neoprene. I like the stockers better. Just my personal opinion, I'm sure others will say otherwise.
 Here's the link for the stockers...only $33.00, can't go wrong. ???
http://www.hdlparts.com/fiche_section_detail.asp?section=2136858&category=Motorcycles&make=HONDA&year=1999&fveh=124888
joefromperry
Perry, OH
« Reply #2 on: June 30, 2012, 06:05:47 AM »
I just installed a set I got from my local Honda dealer. $42, but it took three days for him to get them. It feels like it makes a difference.
2000 Honda Valkyrie Interstate Silver/Blue
2002 Honda Shadow ACE Deluxe
1972 Honda CL350K4 Scrambler
2008 Ural Patrol
1987 Honda Rebel 450
9Ball
« Reply #3 on: June 30, 2012, 06:16:29 AM »
where are you located?  add that to your profile and it will aid in getting help....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #4 on: June 30, 2012, 06:31:43 AM »
Crud, 06410-MBH-000 is what I ordered just the other day from HDL...
No notice from them yet that it is backorder...
« Reply #5 on: June 30, 2012, 10:03:13 AM »
Those aren't things that normally go bad.
Pretty east to inspect when the wheel is off.
They will have some engineered slop in the fit with the wheel to allow for the star to insert.
A good look at is all that's necessary.
You'll be able to see easily if they are bad, or not.
Disco
Republic of Texas
« Reply #6 on: June 30, 2012, 05:38:43 PM »
I do, too.  I've never ridden with the harder compound dampers, but firmly believe the role of the damper is to absorb driveline lash, not transfer it to other, more costly parts.
Sure they do.  Whether from time, miles, abuse, or a combination, we've replaced a number of sets down here.  I replaced mine at 12 years and 38,6XX miles.  If yours are loose in their pockets, you will feel a significant reduction in lash upon replacement.  Mine were and I did.  My initial reaction was that it seemed like my right wrist was directly connected with the rear tire's contact patch.
If yours have anything close to slop, you will notice a big difference installing new ones.  Old ones will fall out.  New ones are quite snug and will have to be persuaded to fit in their pockets.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
tank_post142
south florida
« Reply #7 on: June 30, 2012, 06:07:40 PM »
always order the I/S dampers. they are one piece and seem to last a little longer as they do not develop slop between the inner block and the cushion only shrinkage from the outside.
I got a rock Sad
VRCCDS0246
lifguardct
2000 Interstate, 2009 Stratoliner (2007 ZX14 sold)
Southwest Florida
« Reply #8 on: June 30, 2012, 07:24:37 PM »
When I look them up for a 1999 it shows the same part number for all models. Is there another part number for different years on the Interstate?
tank_post142
south florida
« Reply #9 on: June 30, 2012, 07:27:52 PM »
I/S are the same , early standards and tourers used an inferior 2 piece design.
I got a rock Sad
VRCCDS0246
wild6
(Old enough to know better)
Vernon, NJ
« Reply #10 on: July 03, 2012, 06:33:10 AM »
Part 06410-MAH-A60 is the two-piece version to avoid.
Use 06410-MBH-000.  It is one-piece and fits all years/models.
etiwandablues
Kennewick, WA
« Reply #11 on: July 03, 2012, 07:42:37 AM »
Just ordered and received 06410-MBH-000 from www.hondaparts-direct.com, $32.85
6pak2go
Somewhere in New Mexico #30112
Hanover, Indiana
« Reply #12 on: July 03, 2012, 09:54:03 AM »
not sure who, i think chris, said to put them in the freezer overnight so they will drop in easier without to much persuasion involved.
« Reply #13 on: July 05, 2012, 04:37:15 PM »
My dampers came in today, ordered last Wednesday night, showed up today...
Tire showed up a few days ago...
-Mike "new rear tire for inzane..."
« Reply #14 on: July 06, 2012, 01:36:45 PM »
[quote  cooldude cooldude, i think chris, said to put them in the freezer overnight so they will drop in easier without to much persuasion involved.
[/quote]  That is perzackly what i did to get mine in easy. I have a big upright freezer in my garage which(the garage)houses my fat lady. Wink I'm just guessing here but i believe the ones i removed were the originals-60818 miles and a little over 13 years old. coolsmiley There is a marked difference from the old ones to the new ones-way better. cooldude And it feels just like my right hand goes to the tire contact patch. cooldude RIDE SAFE.
