February 05, 2026, 08:11:31 AM *
Author Topic: Buzz Bolt & Company  (Read 1345 times)
Sodbuster
« on: July 02, 2012, 08:10:55 PM »
I had been dealing with the buzzing noise long enough and decided to go after that darn buzz bolt behind the radiator. I tried torquing it down and would be somewhat less but still some buzzing noise. I had it torqued to 85 lbs/ft and still buzzing but not as much. Finally figured out it wasn't just the buzz bolt but also the chrome frame cover I have just in front of the gas tank. Seeing as how I wanted to change the coolant anyway I took off the radiator and went after that buzz bolt. I couldn't see how it had any end play axially as it was a tight fit but does have clearance with the bolt so I drilled and tapped two holes for a couple of #8-32 SST setscrews and forced the tube up against the bolt.
The frame cover I just put some velcro on the inside to keep it from touching the frame.
What a difference being able to ride and not hearing that buzzing sound anymore
VRCC # 30938
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: July 02, 2012, 09:01:50 PM »
We pump the tube full of RTV silicone sealant and put some in the cups the tube rests in.  Torque it down and no more rattles.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Sodbuster
« Reply #2 on: July 03, 2012, 06:39:37 PM »
That will be fun taking that bolt out someday  Roll Eyes
VRCC # 30938
« Reply #3 on: July 03, 2012, 10:23:06 PM »
I had the same problem years back.  After tightening it reasonably hard, no joy.  So I tightened it with every ounce of strength I had with two hands on the wrench (and the bolt did not break) and that did it.
It did drive me crazy for a while, as I like OE exhaust and can actually hear things.
