August 17, 2025, 07:27:40 AM *
Author Topic: Kury foodpegs  (Read 852 times)
PhredValk
Edmonton, Alberta, Canada
« on: July 08, 2012, 03:26:55 PM »
So I finally get time to install my Kury foot-pegs. Remove the left peg mount (easier than the right side), get it all apart to find the stock hinge-pin won't go thru the holes in the adapters. Took a half hour to get it back on so I can ride to the hardware store (once you figure out the spring it's easier). Had to get a pin, some washers and cotter pins. Just a warning...
Yopu can see the hinge-pin is way too long, but it has several holes for the cotter pin, and can be cut off.
Fred.
VRCCDS0237
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: July 08, 2012, 07:13:49 PM »
You do things the hard way don't you?  Bolt, 2 washers and a lock nut replaces the pin and cotter pin.
Marty
PhredValk
« Reply #2 on: July 09, 2012, 06:00:53 AM »
I like the hard way, and the new pin is way shinier than the old one. I would have had to go to the hardware store for bolts and lock nuts anyway...
Fred.
VRCCDS0237
DLSSOJC
« Reply #3 on: July 09, 2012, 10:03:20 AM »
I just reused the stock pins and washers, and everything worked perfectly!  cooldude
