February 05, 2026, 10:03:53 AM *
Pages: 1 [2]   Go Down
Author Topic: Need help - Rear Brake Caliper Stopper Bolt  (Read 10641 times)
Cliff
Manchester, NH
« Reply #40 on: July 13, 2012, 08:43:37 AM »
yes it is called the "fender washer mod"  it worked for me,,, Didn't need to do the Nut cage mod.
My rear is a General altimax 205/60-16
http://rides.webshots.com/album/558419637qsIyod?vhost=rides
http://www.valkyrieforum.com/bbs/index.php/topic,43672.0.html
« Last Edit: July 13, 2012, 08:49:55 AM by Cliff » Logged
VRCC # 29680
Fritz The Cat
« Reply #41 on: July 13, 2012, 09:40:05 AM »
Man, something is just not clicking in the old brain. I've gone over the washer mod several times and I just can't grasp the concept. The pics and description are nice but what are you actually accomplishing and what's the board for in the next to the last pic? Do the washers move the end of the bolts away from the tire or do they spread the fender?
RainMaker
Arlington, TX
« Reply #42 on: July 13, 2012, 09:49:04 AM »
It pushes the fender to the right.  I have 3 washers in and mine moved about 1/2 an inch.  I also did the nut cage mods and it took all of that to clear my 206-60-16 tire (Goodyear TT at first then the General Altimax currently on it).
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
BonS
Blue Springs, MO
« Reply #43 on: July 13, 2012, 10:19:02 AM »
The fender brace is held out by the washers. The board helps to do this and make room for the washers. The rear fender is then pulled out by the rearmost fender bolt when it is tightened last.
Fritz The Cat
« Reply #44 on: July 13, 2012, 10:33:22 AM »
Thank you sir.
Pages: 1 [2]   Go Up
