November 24, 2025, 08:31:22 PM *
Author Topic: Fuel valve and filter How?  (Read 2729 times)
groundpounder01
« on: July 12, 2012, 04:39:49 PM »
I have a fuel shutoff valve with a pingle petcock. I want to put an inline filter in as well but dont have room in the line length. Can anyone tell me or have pics of how this is done. I thought of running the line under the chrome bar that is the carb rack but i think that might pinch the fuel line.           THANKS
X Ring
VRCC #27389, VRCCDS #204
« Reply #1 on: July 12, 2012, 05:42:19 PM »
Remember this is a gravity feed system.  Any up angles in the fuel line will interfere with this which is why increases in fuel line length is not a good idea.
Marty
pocobubba
Pocomoke , Md
« Reply #2 on: July 12, 2012, 06:56:34 PM »
groundpounder , I have a Golan petcock and inline filter , and a Dan Marc electric shut off . I eliminated the stock fuel line tee , got three way block and 3 barbed connectors . I cut the connectors back 2 barbs , bought flexible fuel line , made the two lines to the carb banks a little longer so the tee could move forward a bit . Everything fit just fine . I got everything I needed from Golan , Dan Marcand West Marine .
                                 Good luck , Pocobubba
Blaze
Usa
« Reply #3 on: July 12, 2012, 07:52:59 PM »
Here is what I did today. Seems to working great. But I did desmog also.
« Reply #4 on: July 13, 2012, 08:05:44 PM »
Marty
Wrong.  Up angles don't matter.  The whole system is under the tank and there's a "head" of pressure pushing the fuel through.  Fuel line length also doesn't matter at all.  Think about it.
Blaze - your install looks very similar to mine.  Good job.  (Patting my own back too...)
« Last Edit: July 13, 2012, 08:11:18 PM by MarkT » Logged
groundpounder01
« Reply #5 on: July 13, 2012, 08:40:52 PM »
Right on MARKT gas above carb means flow.
X Ring
« Reply #6 on: July 13, 2012, 10:28:05 PM »
Marty
Actually, no I am not.  I have had it happen.  Btw, how smart is it to install a filter so you have to remove the tank and air box to change it?
Marty
Brian
Monroe, NC
« Reply #7 on: July 14, 2012, 06:09:46 AM »
Any sags in the gas line will trap air at the high spots.This will create a restriction that may cause starvation at high speeds. I agree that the gas line should run up to the petcock without looking like a rolling coaster. My in line filter is close to the pingel directly between the rear coils. Removal of the air box is not needed to change the filter. Tank removal is quick using the hose clamps that come with the thumb tabs.
Blaze
Usa
« Reply #8 on: July 14, 2012, 08:19:14 AM »
I can change mine with only fuel tank removed. And really, how often will it need changed anyway?
X Ring
« Reply #9 on: July 14, 2012, 09:47:45 AM »
Explain how you can change it when one of the clamps is under the airbox with the screw head pointing up.
Marty
Blaze
Usa
« Reply #10 on: July 14, 2012, 10:02:52 AM »
Marty
If you really want to know, I don't have to take the clamp off. The filter unscrews. I leave that part in there. I could give you a video if your interested.
X Ring
« Reply #11 on: July 14, 2012, 01:19:15 PM »
Marty
No, that's alright.  You've answered my question.  If you don't mind me asking, who made the filter?
Marty
Blaze
Usa
« Reply #12 on: July 14, 2012, 01:33:05 PM »
No problem. Its a Mr Gasket.
pocobubba
Pocomoke , Md
« Reply #13 on: July 14, 2012, 02:10:56 PM »
Marty ,
      My Golan filter unscrews also .
                                                  Pocobubba
X Ring
« Reply #14 on: July 14, 2012, 03:05:30 PM »
I use a Wix filter for a 460 Ford with spring clamps on each end.
Marty
Brian
Monroe, NC
« Reply #15 on: July 15, 2012, 05:19:14 AM »
Marty
I too am using the Wix filter with the spring clamps. I like the idea of one that unscrews but then again like the man stated, how often are you changing these?
X Ring
« Reply #16 on: July 15, 2012, 07:31:54 PM »
Every other oil change.  I consider it cheap insurance.
Marty
groundpounder01
« Reply #17 on: July 17, 2012, 07:08:42 PM »
X Ring wher did you mount your filter?
X Ring
« Reply #18 on: July 17, 2012, 07:49:44 PM »
The nipples for the Pingel and the filter almost touch, if that helps.  The filter is about a couple inches long so I can get to the spring clamps with  90* long handle needle nose pliers.
Marty
groundpounder01
« Reply #19 on: July 18, 2012, 10:16:06 AM »
XRing are you running a electric fuel shut off,and is your valk desmoged?
X Ring
« Reply #20 on: July 19, 2012, 11:53:34 AM »
Both of my Valks are desmogged.  My Tourer has a belly tank so no need for a Dan Marc.  My I/S has a stock fuel system except for the Pingel and fuel filter.  I try to remember to turn off the petcock every time but sometimes I don't.  Even so, every time I start, I tap the start button a couple of times to make sure I don't have hydrolock.  I'm planning to install a belly tank on it also.  Until I do, I'm probably going to install a Dan Marc.  $25 for the Dan Marc vs $400 for the belly tank vs $1K+ for hydrolock repair.
Marty
