February 05, 2026, 01:08:47 PM
Fender/passenger seat bolt
Topic: Fender/passenger seat bolt (Read 1182 times)
Davemn
Minnetrista, Minnesota
July 17, 2012, 04:10:47 AM »
My nut under the fender is stripped (6x20 I believe). Can I just put a nut on it w/a longer bolt or can it be retapped for a larger bolt? I cant tell what material the nut is without some disassmbly.
tank_post142
south florida
Re: Fender/passenger seat bolt
July 17, 2012, 04:16:13 AM »
well id consider a retap. longer bolts and nuts tend to hit tires. the other option could be a shallow panhead bolt from the inside with a nut on the top.
I got a rock
VRCCDS0246
July 17, 2012, 06:21:16 AM »
I put a nut under mine, works fine. I always split the fender when I remove the rear tire. Hoser
Last Edit: July 17, 2012, 10:53:09 AM by Hoser
