February 05, 2026, 01:08:13 PM *
Author Topic: CT Choices  (Read 3294 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: July 17, 2012, 04:16:52 PM »
I am looking at going back to CT.
I wanted the Falken Ziex 512. No longer available in the size I want, 205/60/16. I then decided on the Kumho run flat, same story, not available in the size I want.
  I did lots of research and like the looks of the following three. Anybody running any of these? Like them?
                Bridgstone Potenza G 019 Grid, V-rated 205/60/16
                Sumitomo HTR A/S PO1, V-rated 205/60/16
                Yokohama Avid Envigor V-rated 205/60/16
When I make my choice, I have a new Avon Cobra 200 with 600 miles on it that will be for sale as well as a GoodYear Triple Tread with no visible wear.
I will post them when I'm ready with my new tire. Both will be cheap.
« Last Edit: July 17, 2012, 04:19:51 PM by Tundra » Logged
Hog Killer DS0048
Tucson, AZ
« Reply #1 on: July 17, 2012, 05:13:10 PM »
I'm on my third Potenza with no complaints.
KSDragonRider
Salina, KS
« Reply #2 on: July 17, 2012, 05:54:14 PM »
I have the 512 and love it, but i would not be afraid of this tire either:
http://www.discounttiredirect.com/direct/tires/falken/size/viewProductDetail.do?pc=18693
This is the tire we put on a friends bike.
I have not riden the bike with that tire, but he claims he can not feel the difference between it and the bald avon he took off the rear.
Another friend just put a douglas from walmart on the rear of his, and after about 300 miles, he claims to hardly notice a difference.
hope that helps and adds to your list of things to think about.
Dalen & Shay -> Salina, KS
VRCC Member #33950
Thunderbolt
Worthington Springs FL.
« Reply #3 on: July 17, 2012, 05:56:58 PM »
I don't remember if mine is the G019, but as you probably remember, I am running the Potenza on the Rocket III, it's a 225/60-16.  Valkyrie has a 205/60-16 Bridgestone HP550 on it.  I probably have only around 15000 on the HP550, but it is getting a little long in the tooth, without looking at the records, I think I have had it on for 4 years.  Probably time for a new one.  Iris really likes the ride better than the bike tire.
TJ
Lake Placid , Fl.
« Reply #4 on: July 17, 2012, 06:47:08 PM »
 tickedoff Put the 205/55 on and if you don't like it, I'll buy it from you............
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #5 on: July 18, 2012, 02:38:42 AM »
I like that tire , tread pattern and rounded edges. Want it in a 60 series,
I just don't want to run a 55 series and increase my RPM and drop fuel milage.
JC
The Beast
Franklin, TN
« Reply #6 on: July 18, 2012, 06:24:45 AM »
I'm 5000 miles into a Potenza G019 205/60-16 and I love it! First time Darkside rider, I don't see myself going back. Once past the short learning curve (~100mi.) and tire break-in (~1400mi.) it rides as well as or better than a MC tire.
Grumpy
Tampa, Fl
« Reply #7 on: July 18, 2012, 07:35:33 AM »
Still running the Austone Taxi tire and loving it, 3200 miles on it now.
matt
Derry New Hampshire
« Reply #8 on: July 18, 2012, 10:50:48 AM »
I thought the general altimax was the tire of choice? but i do like the look of bridgestone  g019  but why v rated not h
« Last Edit: July 18, 2012, 11:00:57 AM by matt » Logged
WamegoRob
Wamego, KS
« Reply #9 on: July 18, 2012, 11:12:58 AM »
Not that most would ever have the need but 'V' is rated for about 20mph more than 'H' and is the sports car tire of choice, unless you're rich and have a car worthy of 'Z' tire.
Also.. perhaps you'd want to inflate to a psi higher than to what an 'H' is suited.
« Last Edit: July 18, 2012, 11:15:35 AM by WamegoRob » Logged
matt
Derry New Hampshire
« Reply #10 on: July 18, 2012, 11:16:02 AM »
I know about the speed rating, was just wondering if the v having a stiffer sidewall worked better on bike.  Trying to go darkside
« Reply #11 on: July 18, 2012, 11:35:42 AM »
There is not any notation on the tire regarding sidewall "stiffness" and there is no relationship of stiffness of the sidewall to the speed rating of the tire.
There is a ply rating of a tire but refers to the actual number of plies but again can be considered arbitrary because you can have a 4-ply tire that is rated a 6-ply tire.
I think the tire type such as LT (light truck) might be considered as a clue to sidewall thickness/stiffness but is not a sure thing.
You can find some of the higher speed rated tires with lighter weight when compared to lower speed rated tires that can be found considerably heavier.
I most always look for the heavier tires feeling they are the best for my Valkyrie when compared to the lighter tires. All the tire manufacturers post their tire weight.
lifguardct
2000 Interstate, 2009 Stratoliner (2007 ZX14 sold)
Southwest Florida
« Reply #12 on: July 18, 2012, 12:41:14 PM »
Is that a 205 or 195?
Grumpy
Tampa, Fl
« Reply #13 on: July 18, 2012, 05:57:08 PM »
  neither, 175 r 16 6ply
RiderNJ
'99 I/S Black and Chrome
Southern New Jersey
« Reply #14 on: July 18, 2012, 06:25:15 PM »
+1 on the Austone.     I just did an 1100 mile trip and now have 2000 miles on mine.  Loving it.
RiderNJ
"Our real problem, then, is not our strength today; it is rather the vital necessity of action today to ensure our strength tomorrow." Dwight D. Eisenhower
NJF6Cowboy
« Reply #15 on: July 18, 2012, 08:08:13 PM »
Tundra,
I have just mounted my 5th car tire on my Valk Interstate. Leaving Friday am for South Dakota, Montana, and Wyoming road trip and needed new tires. Approximatly 85,000 miles on rear car tires.
I tried the Yokohama Avid Envigor V-rated 205/60/16 this time and I think it is the best handling tire I've had to date. Prior to this I ran a Dunlop Sport, Toyos, a General Altimax which I thought was great. But the Yokohama has that rounded tread when mounted and I have no rub issues as with the other tires.
WamegoRob
Wamego, KS
« Reply #16 on: July 19, 2012, 09:43:12 AM »
I fear that I'm giving the Falken ZIEX ZE-512 a bad name since I've been rescued from the side of the interstate by a trailer-hauling Hozer twice in the last couple of months.
But... it's not the tire's fault.  The first one was a faulty valve stem and yesterday I picked up a nail.
steve 3054
VRCC # 34853
Sanford,Fl. 352-267-1553
« Reply #17 on: July 19, 2012, 05:19:18 PM »
I for one was somewhat reluctant to go to the CT...I can honstly say that I can not tell there is a CT back there...I am running the Potenza 205/60/16...and I CAN'T tell...
Be polite. Be professional. But, have a plan to kill everyone you
 meet.
cutter
Plantersville, Texas
« Reply #18 on: July 20, 2012, 08:25:59 AM »
Been running the Yokohoma Avid since it came out and about due for a new one.  cooldude
stude31
Topeka,ks
« Reply #19 on: July 20, 2012, 11:48:44 AM »
Discounttiredirect.com has falken 512 in the 65 series they are discontinued but they said they have 20 left I bought four of them.... Get them while they still got them! 205/65/16
MrKris
Auburn, AL
« Reply #20 on: July 20, 2012, 12:31:54 PM »
Really?  I just bought one from them about a week ago, same size.  I like it so far, maybe I should buy a couple more.
stude31
Topeka,ks
« Reply #21 on: July 20, 2012, 01:40:07 PM »
I would
Mr.BubblesVRCCDS0008
« Reply #22 on: July 20, 2012, 05:50:05 PM »
I'm on my second Potenza G019 205/60-16  now and it is one of the best CTs that I've ran. I get the V rated tires because I had a  wobble from the only H rated tire that I ever ran. It was up arround the triple digit area where it started to wobble. I've never had this with a V rated tire. I keep 38 psi in all my CTs as more seems to wear the centers out early.
Rosie
Clintonville WI 54929
« Reply #23 on: July 22, 2012, 05:49:33 PM »
What would be the size closest to mc tire in a car tire and will it rub without doing modifications 2UP pulling trailer. Would like to keep the height of the tire about the same, dont need any more RPMs at highway speeds. Thanks
1999 Valkyrie tourer
2003 Valkyrie standard
« Reply #24 on: July 22, 2012, 07:03:37 PM »
60 series is pretty close to stock tire height. Do the mod while the tire is off it is very easy to do. I would be worried going 2 up and loaded without doing the mod.
PhredValk
Edmonton, Alberta, Canada
« Reply #25 on: July 22, 2012, 08:28:20 PM »
Falken Ziex ZE-512 205/65R-16, love it. The pic is at 17k+ miles...
70 MPH at 3,000 RPM.
Fred.
VRCCDS0237
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #26 on: July 23, 2012, 05:04:35 AM »
Fred.
   Very interesting...   my 205 60 16 GTT runs 3000 rpm @ 70 mph too ???
Does that mean the Falken 65 diameter is the same as Goodyear 60?
