January 28, 2026, 08:05:02 PM *
Author Topic: Ready to go to the Darkside  (Read 3036 times)
Kilroy
Clearwater, Florida / Overland Park, KS
« on: June 02, 2009, 07:29:05 PM »
Hi All,  I picked up a Potenza G019 Grid  205 60 R 16 today for my 03 Standard and am ready to have it mounted.  I will be doing the nut cage removal for the clearence.  While I am at it I will of course do the rear end maintance, just a couple of questions.  I will be changing the 3 O rings and the final drive fluid.  Planning on using Bel Ray waterless grease on the splines.  I would also like to check the drive shaft what lube should I use on the end of the driveshaft?  Also anything else I should do? Thans,
Kilroy
"I was here, but now I'm gone"
Thunderbolt
Worthington Springs FL.
« Reply #1 on: June 03, 2009, 03:23:05 AM »
I did the washer mod also to pull the right side of the fender out a little.
Shades
Gaffney, SC.
« Reply #2 on: June 03, 2009, 03:33:35 AM »
Your good with the Bel Ray that is what I use. Good Luck!! Shades
Shades
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #3 on: June 03, 2009, 03:25:22 PM »
Just check the thrust washer. If its thin and flimsy replace it. Other than that it sounds like you have it covered.
RUDE DOG - Steelers
New Jersey - VRCC # 3966
« Reply #4 on: June 03, 2009, 04:38:03 PM »
I just went Darkside a couple months ago.  I used the Bel-Ray waterproof on the rear splines and pretty much everywhere else but Valvoline Syn Power synthetic grease on the driveshaft splines as was suggested here by many.  You can get it at most auto parts sotres.  Also replaced the 3 O-rings and the thrust washer and changed the rear differential fluid.  Make sure when installing the rear hub/drive if removed you snug the 4 bolts, install the rear wheel and then fully tighten the hub/drive bolts.  I did the fender washer mod and the nut cage.  Might be better to do the fender washer mod first and see if you need to do the nut cage mod.  Only the fender mod may be necessary and is reversable whereas the nut cage isnt.
Dan Manko
« Reply #5 on: June 03, 2009, 05:09:39 PM »
Steelers,
 What brand tire is that in the picture?
RUDE DOG - Steelers
« Reply #6 on: June 03, 2009, 05:12:06 PM »
Yokohama Advan A048.
Duct Tape
Man-servant of QOTFU
Sugar Land, TX
« Reply #7 on: June 03, 2009, 06:56:34 PM »
What is the washer modification?  I don't recall seeing that before.
Rog
"Duct Tape"
Kilroy
« Reply #8 on: June 04, 2009, 07:04:27 AM »
Thanks to everyone for your replys.  I will be using the Bel Ray waterproof grease as well as doing the nutcage mod.  Is it difficult to get the drive shaft out and is it ok to use the Bel Ray on the other end of the driveshaft?
What are your thoughts on that?
SCain
Rio Rancho, NM
« Reply #9 on: June 04, 2009, 07:29:44 AM »
Roger,
Here is the washer mod, see link.
http://www.s2s-accessories.com/photo/fndrmod/
Steve
Steve
RUDE DOG - Steelers
« Reply #10 on: June 04, 2009, 08:40:18 AM »
Once you remove the rear hub, the drive shaft comes out with a small tug.  I used the Valvoline Syn Power synthetic grease on the driveshaft as recommeded by many others.  The Belray is good for most everything else.
Kilroy
« Reply #11 on: June 04, 2009, 10:27:53 AM »
Thank you steelers, was it a big job to get it back where it belongs??
RUDE DOG - Steelers
« Reply #12 on: June 04, 2009, 12:39:11 PM »
Everything went smooth for me.  Just took my time and followed the manual and everyones tips from here.
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #13 on: June 04, 2009, 04:06:06 PM »
Killroy just make sure to lift the swingarm to the normal travel position and it will slide back in. If you have the bike jacked up and the swingarm hanging down the angle is severe making it more difficult.
Kilroy
« Reply #14 on: June 04, 2009, 07:35:53 PM »
Thanks for the hint, should make it go better.
Duct Tape
Sugar Land, TX
« Reply #15 on: June 05, 2009, 04:11:13 AM »
Roger,
Steve
Thanks Steve.  I do not see how that increases the nut spacing.  Is the issue, that the bolts extend through the nuts?  Then a washer would increase the spacing between the end of the bolts.  Or you could grind/cut off the end of the bolt.
Roger
Rog
"Duct Tape"
