February 05, 2026, 01:08:46 PM *
Author Topic: danmark model  (Read 1715 times)
groundpounder01
« on: July 20, 2012, 05:58:28 PM »
Which valve is best to use? The one i have has 1/8 npt threads on it. I was just thinking that might be to small. The bike seems to run fine but i havent rode any mountain rodes since install.
« Reply #1 on: July 20, 2012, 08:12:49 PM »
Is this the valve?
http://www.dan-marcrvparts.com/12vomufushof.html
I installed this one on my ride and it's been working fine. It has the 1/8 inch inlet and outlet.
My rides:
Chattanooga Mark
« Reply #2 on: July 21, 2012, 06:02:36 AM »
I'd suggest you follow these excellent instructions from MarkT. I'm glad I did everytime I press the start button. http://horseapple.com/Valkyrie/Tech_Tips/Fuel_Shutoff/fuel_shutoff.html
All the best,
Mark
www.bikersforchrist.org
shooter64
« Reply #3 on: July 22, 2012, 03:13:27 AM »
I keep thinking I might get one of those but the fuel line is 3/8". Will it work at full throttle through a 1/8" inlet/outlet? My riding mower has a bigger fuel line than that.
Columbia, S.C.
Gear Jammer
Yeah,,,,,It's a HEMI
Magnolia, Texas
« Reply #4 on: July 22, 2012, 05:35:47 PM »
The DanMarc fittings are not 1/8",,,They're 3/8"  openings on both ends.  The fuel line is 5/16" ID.  You'll use an adapter with a 3/8 threaded fitting with a 5/16 barbed hose fitting.  I've got one, and no problems with flow at any speed.
« Last Edit: July 22, 2012, 05:41:35 PM by Gear Jammer » Logged
X Ring
VRCC #27389, VRCCDS #204
« Reply #5 on: July 22, 2012, 05:43:14 PM »
I don't think the DanMarc fittings are only 1/8",,,The fuel line is 5/16" ID.  I've got one, and no problems with flow at any speed.
The inlet/outlet fittings are 1/8 NPT.  They do have fuel solenoids with larger fittings but they are more expensive.
Marty
« Reply #6 on: July 22, 2012, 07:58:10 PM »
Gear Jammer and Mark thanks for the very important clarifications regarding the valve openings. I re-read my post above and see that it lacks specificity and could be easily misunderstood/misleading.
My rides:
