February 05, 2026, 11:48:50 AM *
Author Topic: Rear rotor - How long?  (Read 1301 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: July 22, 2012, 07:38:32 PM »
How long should the rear rotor last under normal conditions?  I have 50k on mine and I do feel a slight ridge around the outer edge.
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
Tropic traveler
Silver Springs, Florida
« Reply #1 on: July 22, 2012, 07:43:14 PM »
I got 100K out of the rear rotor {fronts too} before I replaced them, '97 Tourer. They weren't pretty and maybe I could have gotten a few more miles out of them but I was in a renew at 100K mindset at that time. Wink
I have heard of others going longer that that as well.
'13 F6B red for Kim
Madmike
Campbell River BC, Canada
« Reply #2 on: July 22, 2012, 08:24:12 PM »
I think theer is a min thickness right on teh rotor - if not there then for sure in teh manual.
« Reply #3 on: July 22, 2012, 09:17:06 PM »
Most or all rotors will develop a slight ridge around the outside edge (metallurgy, with brake pad pressure pushing it up) for some time before they reach end of life (minimum thickness).  Can make putting calipers with new pads back on over the rotors difficult/tricky.  Mine are still within limits, but definitely have ridges.
Rio Wil
« Reply #4 on: July 22, 2012, 09:21:24 PM »
I have 165K on both front and rear rotors. The fronts are due replacement now and will do it in the next few weeks. The rear has a fair groove but will be good probably another 40K. I do find that the rear brake is getting more use because the car tire adds so much more traction in all aspects that the rear brake is actually useful across a much broader range of braking situations.
« Reply #5 on: July 23, 2012, 05:28:22 AM »
You should easily get another 50K out of it...unless you are a "back braker"  This is a dangerous habbit of relying on the back as the primary brake and the fronts as a back up.
cutter
Plantersville, Texas
« Reply #6 on: July 23, 2012, 06:12:02 AM »
at 226000+ miles I'm on my 3rd set of front rotors and still running the OEM rear rotor....  uglystupid2
