February 05, 2026, 11:43:25 AM *
Author Topic: Kill Button....No Response  (Read 1249 times)
shavdog
Walker, Minnesota
« on: July 24, 2012, 05:05:11 AM »
On my 98 std....I push the red kill button on the handle bar...nothing happens...seems dead...I use to key to shut off but would like my kill button to work....looking for ideas where to look..thanks...craig
« Reply #1 on: July 24, 2012, 05:38:36 AM »
Spray some WD-40 in and around the red switch and then function it many many times......that should fix it
« Reply #2 on: July 24, 2012, 06:05:35 AM »
You have very few posts. Is your Valk new to you. It's possible the PO bypassed it. Open the switch housing and see if the wires are jumped.
shavdog
Walker, Minnesota
« Reply #3 on: July 24, 2012, 06:57:46 AM »
you are correct...this valkyrie is new to me...not sure what you mean by  "jumped" but I will try the wd40...thanks.
Fritz The Cat
« Reply #4 on: July 24, 2012, 07:37:47 AM »
No way I'd spray WD40 in there. Radio Shack contact cleaner is better suited for the job.
« Reply #5 on: July 24, 2012, 08:06:56 AM »
Probably better, but WD-40 fixed mine right after I got the bike and never had a problem for years after that........theres always something better, but WD-40 and duct tape fixes almost anything Cheesy
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #6 on: July 24, 2012, 11:37:58 AM »
I 2nd this. Some people don't like the kill switch functioning and jump (or disengage it) and you may need to reconnect the wiring for it to work.
