February 05, 2026, 11:43:30 AM
Another starter solinoid question
Topic: Another starter solinoid question (Read 1932 times)
Maldog
Woodstock IL
July 24, 2012, 12:46:05 PM »
Im going to purchace a new solinoid for my IS,, Honda wants around 100 bucks for it,Honda Direct want 70 bucks for it and when i went to Ebay I was seeing aftermarket starter solinoids for Valkyries for between 23 and 30 or so well the cheep SOB in meay get it on EBAY ,My question is have any of you gents purchaced a solinoid on EBAy and if so were you pleased with it, did it perform well,, My buget is fairly tight as Im on lay off and wanna fix my IS as prudently as possible but dont wanna buy sub quality stuff either ,and Thanks guys for all the responces to all my recent posts about this stuff, you guys are great and its all been very helpful,thanks again ,Mal
Re: Another starter solinoid question
July 24, 2012, 09:42:07 PM »
Ah, I think there may be a wording problem here. I don't think the Valk has a solinoid.
It does have a starter relay. And other Honda bike use the same relay, the VT1100 for one, I sold my IS relay to a fellow ACE Tourer forum member.
I don 't think I've hear dof too many of these going bad. But I do of the wires melting. Sure you need another relay?
Last Edit: July 24, 2012, 09:57:20 PM by gordonv
junior
new hampshire
July 25, 2012, 01:48:13 AM »
i have had a aftermarket selinoid sence 07 and this is the way i wired it in
and i havent had a bit of problems with it
Rattlebars
Liberty Ohio
July 25, 2012, 03:09:05 AM »
You will just have the same problems eventually if you get the one from eBay. Your start relay/solenoid is probably ok, just needs a little work and about $6 worth of parts.
Complete write up here
>CLICK<
Or just click the pic below:
Have you had your pre-frontal Limbaughtomy today?
'98 Valkyrie NYTMR
Vietnam Vet - Infantry Recon '66-'71
