February 05, 2026, 11:48:48 AM *
Author Topic: bad safety switch ?  (Read 1474 times)
fubar606
eastern washington
« on: July 25, 2012, 07:36:56 AM »
here's the deal i have a 2000 I/S won't start in gear with clutch in kickstand up . i checked the clutch switch it activates and is a good switch (tested). so if i kill it in and intersection you half to find neutral to restart  Sad.  so what do i check next?
life is sexually transmitted and always fatal
« Reply #1 on: July 25, 2012, 07:48:16 AM »
Simple things first......clutch lever bushing, interlock switch on clutch
kenf
2000 Interstate
Ontario Canada
« Reply #2 on: July 25, 2012, 07:54:42 AM »
Had the same problem and found the wire connecting the safety switch at the clutch lever unplugged. Plugged it back in and all was ok. Seemed too simple but sometimes simple works.
[IMG]http://i1253
[IMG]http://i1253
fubar606
eastern washington
« Reply #3 on: July 25, 2012, 07:58:11 AM »
the lever is activating the switch the wires are making contact, looks like the problem is not at the handle bar sight where do i look next?
Michvalk
Remus, Mi
« Reply #4 on: July 25, 2012, 09:06:41 AM »
Sidestand switch? Undecided cooldude
fantsybikr
O HI O
« Reply #5 on: July 25, 2012, 09:42:40 AM »
I had same problem..replaced the bushing in the clutch lever.. The bushing is oem part number..22885-MB0-006. Costs about 12 dollars, fits all valks. Hopefully this helps.
« Last Edit: July 25, 2012, 09:48:14 AM by fantsybikr » Logged
VRCCDS 0252
  VRCC   26284
 GWRRA 329832
Rocketman
Seabrook, Texas
« Reply #6 on: July 25, 2012, 02:15:27 PM »
It sounds like you've even run an ohm check on your clutch switch.  That rules out that switch.
Sidestand switch is the only other thing that cares whether you're in neutral or not.  Do the same thing there, and you'll probably find your culprit.
Mark
fubar606
eastern washington
« Reply #7 on: July 25, 2012, 02:30:28 PM »
Mark
                                    OK thanks for input
fubar606
eastern washington
« Reply #8 on: July 25, 2012, 04:06:38 PM »
checked my kickstand switch the mounting bolt was loose just enough for it not to work cleaned it up tightened it up works great.   yheeea cooldude cooldude cooldude
                          I love this board and the people thanks to you all
Rocketman
Seabrook, Texas
« Reply #9 on: July 26, 2012, 08:05:24 AM »
I'm glad it was so simple.
That's actually a nice little reminder to check those bolts.  I'd hate to have the kickstand fail on me one day.
