February 05, 2026, 02:34:42 PM *
Author Topic: Squeak in rear  (Read 1395 times)
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« on: July 26, 2012, 06:13:33 PM »
Replaced car tire, o-rings, greased and re-assembled. Torqued everything to specs (axle and pumpkin) and now I have a slight squeak.
When on the jack in nuetral the wheel spins free and all you hear is the disc brake when you spin it either way.  Ride it and around 25mph I hear a squeak from the rear.  Shut the motor off and you still hear it.
When the wheels were off the bearings turned free and even the shop that changed the tire said they were great.
Thoughts?
« Last Edit: July 26, 2012, 06:17:49 PM by Zeus661 » Logged
Dropbox is a neat app I found that I use to store files and pictures of my Valk.
justintyper
syracuse,ny
« Reply #1 on: July 26, 2012, 06:25:34 PM »
greased the splines but what about the pinion cup and the drive shaft splines and u joint? id check there next...
« Reply #2 on: July 26, 2012, 06:49:30 PM »
maybe you are lucky and its only the plastic dust ring on the final drive....sometimes it gets knocked crooked and rubs on the wheel....if thats the case you may be able to pop it back straight without removing anything
« Reply #3 on: July 26, 2012, 07:06:38 PM »
Mine did that when I turned right. Loud enough I thought it was a bearing. I washed the bike and it was gone.
olddog1946
Moses Lake, Wa
« Reply #4 on: July 26, 2012, 07:06:40 PM »
change the bearings...I didn't and in under 1000 miles when it (lft side bearing) went, I had 20%  wear on my splines. Mine felt good when I did my maintenance, but obviously weren't.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #5 on: July 26, 2012, 07:45:06 PM »
All that was done.
Toledo Mark
Formerly Zeus661
Rossford, Ohio
« Reply #6 on: July 26, 2012, 07:46:32 PM »
That is exactly what I did except you heard it rolling straight down the road.  I wet both sides of the rear and it went away.  Will ride it tomorrow and see.
« Reply #7 on: July 26, 2012, 08:09:22 PM »
Did you lube the dust seal on the Left side that goes on the goes over the spacer?  That was my squeak.  Put a little grease on it and it was gone.
