February 05, 2026, 02:50:58 PM
Rear Wheel Swap
Topic: Rear Wheel Swap (Read 1489 times)
ptgb
Youngstown, OH
Rear Wheel Swap
July 29, 2012, 08:17:33 PM »
Search was not my friend on this one. After looking through prior posts I am even more confused.
I have a 1999 Interstate with chrome wheels. I am redoing a 2001 Standard into a chromed out show bike. I want to swap the wheels on the bikes.
Do I simply swap wheels (I know the front wheels match) between my Valks or do I have to change the rear brake rotors to keep the I/S rotor with the I/S and vice versa?
Thanks.
Re: Rear Wheel Swap
July 29, 2012, 08:44:40 PM »
Check the rear rotor bolts. If they look the same, just swap away. If they look different, then you can sawp the wheel/rotor together. It's possible the brake caliper with bracket have to be swapped too.
Re: Rear Wheel Swap
July 30, 2012, 05:08:20 AM »
Any Valkyrie rear wheel will fit on any Valkyrie if it has ITS PROPER disk.
Where you get into trouble is changing out the rotors. A '97 bike will accept a 2003 rear wheel if it has the 2003 rotor disk and vise verse
wdvalk
Katy Texas
Re: Rear Wheel Swap
July 30, 2012, 05:19:12 AM »
you can check the wheel by casting number,inside the hub on the rotor side there will either be the code j1 or j2
tank_post142
south florida
Re: Rear Wheel Swap
July 30, 2012, 07:23:56 AM »
Like Chris said: just keep the wheel and rotor together and you have no problems.
I got a rock
VRCCDS0246
