« on: July 31, 2012, 10:28:40 AM » |
Hi all, I have noticed over the last few years that when the engine is quite hot (coolant temperature 200°F+) and the clutch lever is within 1/2" of the hand grip, there is a loud bearing type of noise coming from the transmission area. Because this problem is intermittent depending on heat, I have ignored it, but I would like to know if it is a concern and which part needs attention. I've included these drawings for you to refer to, if needed.
« Reply #1 on: July 31, 2012, 10:32:45 AM » |
Mine has done that ever since Ive had it (10 years) .....only when it gets REAL hot
« Reply #2 on: July 31, 2012, 11:06:09 AM » |
I'm sure both of you have come to some kind of an explanation for the noise!
Why don't you share?
« Last Edit: July 31, 2012, 11:08:43 AM by Ricky-D »
« Reply #3 on: July 31, 2012, 11:59:12 AM » |
synthetic oil helped.....otherwise works fine....no explaination other than what has been stated
« Reply #4 on: July 31, 2012, 01:11:19 PM » |
I'm sure both of you have come to some kind of an explanation for the noise! Why don't you share?
My question wasn't a trick question designed to find out if anyone else had solved this, and thus was as clever as me. Unless anyone else says that the noise is a predictor of _____ disintegrating, I'm not going to tear into it just out of curiosity.
« Reply #5 on: July 31, 2012, 01:14:17 PM » |
That's good to know; thanks, Chrisj. I also run synthetic oil (currently Mobil 1 15W50).
« Reply #6 on: July 31, 2012, 01:52:01 PM » |
I don't feel the pic you put up GR, was unintentional and I also feel it is the correct one.
There have been a lot of threads which have reported about the "noisy" pin in the clutch slave cylinder.
Maybe it just seeing the same postings repeated over and over again, regardless, I am inclined to hold the same view even though I have yet to experience anything (even remotely) related to that pin.
« Reply #7 on: July 31, 2012, 02:37:39 PM » |
I've read lots about various clutch-related noises, but none in the same circumstances. Clutch out noise: http://www.valkyrieforum.com/bbs/index.php/topic,44997.0.html http://www.valkyrieforum.com/bbs/index.php/topic,44177.0.htmlNoise that disappears after 10 seconds or when put in gear: http://www.valkyrieforum.com/bbs/index.php/topic,42568.0.html
« Reply #8 on: July 31, 2012, 06:19:13 PM » |
That pin is part # 14. I've heard of people removing the slave cylinder and cleaning/lubing the pin. Easy if on a lift.
5_19
« Reply #9 on: July 31, 2012, 06:21:28 PM » |
Hi all, I have noticed over the last few years that when the engine is quite hot (coolant temperature 200°F+) and the clutch lever is within 1/2" of the hand grip, there is a loud bearing type of noise coming from the transmission area. Because this problem is intermittent depending on heat, I have ignored it, but I would like to know if it is a concern and which part needs attention. I've included these drawings for you to refer to, if needed.   I have had the same thing happen to me when it very hot and I was taking a Ride Like A Pro class! The instructor told me go cool of your bike. This happened at the beginning of the class 2 years ago. Haven't had any problems since. At least I know what it sound like when it gets to hot.
 Most motorcycle problems are caused by the nut that connects the handlebars to the saddle. IBA # 45723 2001 Honda Valkyrie Standard (Sold after 9 years) 2009 BMW R1200 GSA
