January 28, 2026, 08:05:01 PM *
Author Topic: coolant leak  (Read 2023 times)
Dan Manko
« on: June 04, 2009, 01:40:08 PM »
Can any one tell me if it's possible to have a leak at the end of the thermostatic switch connection [thermosensor]. I can see coolant leaking out the end of the connector,down the wire and into the protective sleeve that goes out to the right side. I don't see any leaks anywhere else. I pulled the front cover[timing belts] and lifted the rubber flap up, looked from there and
 from the left and righthand sides. I didn't see any other spots of coolant.
Thanks in advance.
SCain
Rio Rancho, NM
« Reply #1 on: June 04, 2009, 02:12:08 PM »
The culprit is probably the radiator hose clamp, see if you can get a long screw driver in there and tighten it up. Take the top radiator bolt out and pull the radiator out a little.
Steve
