April 28, 2026, 05:34:53 PM *
Author Topic: Hey Stan G.  (Read 2947 times)
Curtis_2Valks
« on: September 07, 2008, 07:36:40 PM »
Hey Stan, I got the Continental Vanco car tire mounted Saturday.  Details here: http://forums.delphiforums.com/valkyrie/messages?msg=12140.27
Thanks for the benifit of your experience.  I haven't put many miles on it, but it feels real good so far.
I'm 100% dark side now:
195/65/16 Continental Vanco all season (load rated) on the "big" Valk
195/55/16 Toyo Proxes sport tire on the "little" Valk
Curtis
Rowlett,TX MOOT #315 VRCC #26023
States I've Ridden
There is no lunch too far, nor any need for a reason other than the journey.
Choirboy
Choirboys Valk....
Keller, Tx
« Reply #1 on: September 07, 2008, 10:28:01 PM »
Will the 195/65/16 rub the nut cages? I thought only the 205 tire would do that???
Ready to Ride, Let's get going!!
Patron
« Reply #2 on: September 08, 2008, 05:12:44 AM »
Sure am glad you are liking it!  But, I think you may have a little too much pressure in it.   Even thought this tire will go to a max pressure of 70 psi, I think for the weight we are running it far less pressure may give a more even wear pattern.  I am running 30 in mine and it feels more like a mc tire than any car tire I have tried.  I am just guessing since no one has any experience with this tire on a valk.  Since we are running far less weight than the rating of around 2000 pounds I think less air might produce a more even wear pattern.  With 60 pounds I will bet you are going to wear the center of the tire first.
These tires have a lot of tread depth.  Please let us know, Curtis, how your tire is wearing as you get some miles on it.  Since I put far more miles on my wing, it will be a long time before I know how this tire is going to wear.
Wanderer
The Great Republic of Texas - Dallas
« Reply #3 on: September 08, 2008, 06:43:15 AM »
"one and one half million horses and mules of the confederate and union armies which were killed or wounded or died from disease in the Civil War"  Wow, learn something every day (not checked on Snopes)! ~Jeff
More Valk Pics...
had a couple of Valks once upon a time
2004 DRZ400S
2005 GS1200
1978 CB550K
1977 CB550F
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« Reply #4 on: September 08, 2008, 11:13:04 AM »
I started 'testing' my tire pressure at 32 PSI and found 38 PSI works great for me.  The tire was a bit wobbly at high speed (over 100 MPH) and felt a little wiggly on slower speed turns.  38 PSI seems to stop the wiggles and eliminate the wobbles.  I noticed no difference over 40 PSI.  YMMV
Chuck
Curtis_2Valks
« Reply #5 on: September 08, 2008, 05:54:37 PM »
I don't know.  Because of my hitch being bowed in and pressing the fender in, my right nut cage was rubbing the stock size Avon.  I had to tear everything apart anyway to figure out what was misaligned, and I may run a 205 sometime in the future so I went ahead and opened up the clearances.  I did both the nut cage cut and the fender rail spacer mod so I have plenty of room now.  Also, this tire measured 8.25 inches across before I mounted it on the rim.  I didn't realize it would actually shrink in width after being mounted and aired up.  I think it is around 7.5 or 7.75 inches wide now.
Curtis
States I've Ridden
Curtis_2Valks
« Reply #6 on: September 08, 2008, 05:58:30 PM »
Could be Stan.  I put the car tires on for their increased performance.  The added mileage is a bonus.  If I take a bit of a hit on wear to keep a more rounded profile then I don't count that as loss.  I'll play around with pressures a little to see what's what.  In any case thanks again for your help and suggestions.  I'll keep ya'll posted as I know more.
Curtis
States I've Ridden
