November 25, 2025, 01:53:55 AM *
Author Topic: Need a little help here  (Read 2068 times)
« on: August 08, 2012, 08:41:02 AM »
Just changed out the windshield on my I/S and being as i have the speaker pods pulled-well there be a burned out headlight sooooo thought i would change them out. Key word-thought!! The plugs on the back of the lights have other ideas-not coming off. Is there a trick or a tool or just keep trying??? I have the Honda service manual and the Clymers and they both have pretty much the same pictures Any help or ideas or assistence-mucho appreciated.  cooldude And as always-T I A. RIDE SAFE.
Thunderbolt
Worthington Springs FL.
« Reply #1 on: August 08, 2012, 09:20:19 AM »
Pull harder,they go back on a lot easier.
« Reply #2 on: August 08, 2012, 06:15:55 PM »
After no joy with my fingers i went after it with long needle nose pliers bent at an approx 60 degree angle. And the plug is off and i'll purchase my new headlight bulbs tommorrow. RIDE SAFE.
shortleg
maryland
« Reply #3 on: August 09, 2012, 04:21:52 AM »
  I feel for you. Mine were a BIT.. also.
Replaced them with Silver stars.
  Use some electrical grease when replacing them.
  Shortleg[Dave]
Steve K (IA)
Cedar Rapids, Iowa
« Reply #4 on: August 09, 2012, 08:34:26 AM »
Take the fairing off.  It's really no big deal and will make changing those bulbs a piece of cake.   Wink
States I Have Ridden In
« Reply #5 on: August 09, 2012, 08:44:53 AM »
No need to remove the fairing!
Remove the windshield and the fairing rotates forward revealing the insides of the fairing.
« Reply #6 on: August 09, 2012, 04:11:00 PM »
Replace the bulbs with off-road 80/100 H4's, you'll like them. (just make sure the dims are aimed correctly, and you'll never get flashed) (no touchy the glass)
None of my auto parts stores had them, so I used Amazon.
john
tyler texas
« Reply #7 on: August 09, 2012, 05:25:27 PM »
"Use some electrical grease when replacing them."                             cooldude
vrcc # 19002
« Reply #8 on: August 09, 2012, 05:26:03 PM »
Perzackly what i got from N A P A today-well one of them-going back tommorrow fer da udder one. Did i mention my N A P A dealer is about 32 miles from my house and i still managed to roll up 157 miles today.  cooldude Never ever ever never take the direct route on a Valkyrie.  2funny Ya miss too much.  Grin RIDE SAFE.
« Reply #9 on: August 09, 2012, 05:29:00 PM »
  I'll give that a try. Course you tell me after i install my new to me windshield.  2funny Thanks for the maintenance tip.  cooldude RIDE SAFE.
« Reply #10 on: August 09, 2012, 06:40:21 PM »
Turn the handle bars one direction to allow access to one head light bulb, from behind the speaker panel.
Then get someone with small skinny hands to remove and replace it for you. I had my sister do it.
Used a regular auto light bulb, with the removal of the lower 2 tabs. Did not have a problem with the aiming.
« Last Edit: August 09, 2012, 06:45:07 PM by gordonv » Logged
« Reply #11 on: August 11, 2012, 05:20:08 PM »
  Two good things came from this. Was able to accsess headlight bulbs mucho easier.  Wink Found out my fairing was actually quite loose.  Undecided After bulb install the fairing is now snug on all four bolts.  coolsmiley So Ricky-D thanks fer the maint tip.  cooldude Soon as it gets dark here want to check and see if anything needs a readjustment.  Cool Also raised my handle bars some. Feels good sitting static but that's what test rides are for.  cooldude RIDE SAFE.
« Reply #12 on: August 11, 2012, 09:20:31 PM »
Those 100/80 bulbs i got from N A P A are doing the job RIGHT in the dark. The low beam pattern is nice as are the high beams. Right at $10.00 each and i really like what i'm seeing with them. Just cut off the lower 2 tabs and yer good to go. No readjustment needed at all. Thanks to everyone that offered sugessitions tips and encouragement. This board really do rock.  cooldude RIDE SAFE.
