November 25, 2025, 06:57:43 AM
squeaky clutch lever
Topic: squeaky clutch lever (Read 979 times)
nerider2
Omaha, NE
August 19, 2012, 05:10:27 PM »
How do if fix a squeaky clutch lever?
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
Michvalk
Remus, Mi
Re: squeaky clutch lever
August 19, 2012, 05:22:09 PM »
UUUUUM......grease it?
Actually, remove the screw pin that holds the lever on, and apply the grease to that. You can pull the lever off, and put some on the contact points as well
Pete
August 19, 2012, 06:57:46 PM »
Also grease the brass barrel in the lever. that is separate from the pivot.
Thunderbolt
Worthington Springs FL.
also
August 20, 2012, 03:52:28 AM »
Check to see if the brass bushing is worn into a less than circular pattern, if so replace it.
August 20, 2012, 07:35:14 AM »
A shot of oil every now and then is what's required.
Seeing the assembly is in the windstream all of the time, it necessarily needs regular maintenance.
=> InZane XXV
