February 05, 2026, 06:07:27 PM *
Author Topic: What's the Nilos Ring....  (Read 1755 times)
SpidyJ
Murrells Inlet
« on: August 20, 2012, 07:07:31 AM »
.........that Grumpy is talking about?  0.010" thick.  I want to buy the spacer but don't even know what the Nilos ring is or what it's for?
Thanks.
1999 Fast Black Interstate
Peace,
johnnywebb
« Reply #1 on: August 20, 2012, 07:23:02 AM »
A replacement for an oil seal.  A poor one at that!
« Reply #2 on: August 20, 2012, 07:32:39 AM »
http://www2.nilos-ring.de/default.aspx/G/111327/L/1033/R/-1/T/122934/A/2/ID/122939
A very thin piece of stamped metal....may be used on the outside of the sealed bearing for added protection from the elements (and washing) when doing the left rear two-row bearing upgrade.
http://www.valkyrieriders.com/shoptalk/5204_bearing_mod.pdf
The spacer measured .885” thick before machining and .615” after. The machinist recommended
removing another .010” to be on the safe side. (Editors Note: I don’t like the idea of removing an
additional .010”. If the bearing is .260” wider, remove exactly .260” from the spacer. )
Removing that .010 extra from the spacer may be a good idea IF you will add the nilos ring on the outside of the sealed bearing.
Sabe?
« Last Edit: August 20, 2012, 09:52:17 AM by Jess from VA » Logged
« Reply #3 on: August 20, 2012, 12:14:15 PM »
dust seal, not oil seal.....theres a big difference
T.P.
Apple Valley, Minnesota.
« Reply #4 on: August 21, 2012, 09:03:56 AM »
Your going to need the ZAV model for our sealed bearings.
http://www2.nilos-ring.de/default.aspx/G/111327/L/1033/R/-1/T/122948/A/2/ID/122949
 You will need to order a 5204 ZAV N-ring
Jess you have the wrong N-ring pictured.
« Last Edit: August 21, 2012, 09:11:38 AM by T.P. » Logged
« Reply #5 on: August 21, 2012, 04:13:46 PM »
Thanks TP, it was just supposed to be a link to a nilos ring site for descriptive purposes, not THE one we need.
But yeah, thanks for the specificity (I really didn't know which one was right).
