November 25, 2025, 07:01:12 AM
Help with Horns (non Valk)
Topic: Help with Horns (non Valk) (Read 817 times)
Mase
# 518
August 22, 2012, 11:11:19 AM »
I have a set of "one" wire horns that I want to install on a "two" wire newer (2002) vehicle.
How do I wire this up correctly?
Re: Help with Horns (non Valk)
August 22, 2012, 11:46:16 AM »
On the GM vehicles that I've seen, the green wire is horn power and the black is ground. With a one-wire horn, the mounting bracket acts as the ground. Simply either make sure the bracket has a good grounding connection to the car's frame, or crimp a ring terminal onto the black wire and screw it to the mounting bracket.
August 23, 2012, 06:13:01 AM »
Did you get a 4 horn set (A,C,D, & F tones)? These require a 15A fuse in the original vehicle, so I'm guessing they draw 12A of current. When GM went to 2 wires on these horns, they went to a smaller gauge wire than they used for the single green wire. I'm guessing your Lincoln already uses a horn relay, so I wouldn't worry about adding one.
=> InZane XXV
