November 25, 2025, 04:20:54 AM *
Author Topic: Opinions on petcock choice  (Read 1801 times)
jimmytee
Elizabethtown,KY
« on: August 22, 2012, 06:27:14 PM »
Ok, I've asked this question before but didn't seem to get any responses so here it is.
I am going to replace my petcock. I am trying to decide which one. I'd like the functionality of the vacuum operated valve, but was wondering what others thought and why. Trying to decide between a manual pingle or a vacuum operated one. Any thoughts and why? I saw somewhere someone had a golan with a filter attatched?
Jim
John U.
Southern Delaware
« Reply #1 on: August 22, 2012, 07:17:05 PM »
I'm still using the oem petcocks but it seems to me that at least some of the weaknesses of the oem would be shared by any vacume operated petcock.
I understand that Golan makes a petcock but the general wisdom of this board is that the Pingle is the way to go. Others will weigh in on that.
Golan also makes a high flow fuel filter which I do use. I have had no starvation problems while traveling much faster than the law allows. Golan claims filtration down to something like 6 microns I think.
valkyriemc
NE Florida
« Reply #2 on: August 23, 2012, 04:06:37 PM »
Some reading, refers to an I/S but its applicable;
http://www.valkyrieforum.com/bbs/index.php/topic,44929.msg427051.html#msg427051
Scroll for pics;
http://www.valkyrieforum.com/bbs/index.php/topic,45897.msg436604/topicseen.html#msg436604
Veteran USN '70-'76
Disco
Republic of Texas
« Reply #3 on: August 23, 2012, 07:24:53 PM »
Some good reading here: http://www.valkyrieforum.com/bbs/index.php/topic,32983.0.html
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
donaldcc
Palm Desert, CA
« Reply #4 on: August 23, 2012, 08:38:53 PM »
my choice
« Last Edit: August 23, 2012, 08:40:25 PM by donaldcc » Logged
Don
« Reply #5 on: August 24, 2012, 04:46:26 AM »
PINGLE !  Put one on and you'll never have a problem again..
jimmytee
Elizabethtown,KY
« Reply #6 on: August 24, 2012, 06:45:55 AM »
Patrick, I am sold pretty much on a Pingle, but was wondering about the choice between manual and vacuum operated. I've read posts about switching from the oem but not much on the specifics of why vacuum vs.manual. I am concerned with my discipline in remembering to shut off the manual valve everytime. However, if there is a prevailing thought that the vacuum operated Pingle would be less than optimum or unreliable, I will go with the manual.
Jim
9Ball
« Reply #7 on: August 24, 2012, 09:20:51 AM »
another option is to go with the manual petcock and install the Dan Mark solenoid shutoff.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
« Reply #8 on: August 24, 2012, 09:37:29 AM »
Jim,, I can't tell you a thing about the vacuum Pingle..  But,, I would think that it could eventually have a problem with its vacuum system..
I'm used to ' pre-flight/ post-flight ' checks,, so,, the fuel shut-off isn't much of a problem.. When the right hand heads for the key,, the left hand heads for the fuel valve.. It just becomes second-nature..
Led
Wisconsin
« Reply #9 on: August 28, 2012, 03:09:01 PM »
I just installed a "manual" Pingel in mine this year, and I LOVE it!!  I don't mind turning off my fuel the "old fashioned" way.  Not to mention getting rid of that huge cheap plastic "shutoff" knob that came with it, which no longer worked anymore, anyway............ Cool
Thrud
2000 Valkyrie Interstate
« Reply #10 on: August 29, 2012, 02:24:53 PM »
I have a chrome Golan petcock with the extended pickup tube.  Absolutely love it!
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #11 on: August 29, 2012, 06:31:07 PM »
I just ordered a Golan with the standard length reserve tube. Was going to get the extended tube model, but they admitted the filter screen on the extended tube won't fit into the Valk Std tank, and I didn't want to mess with an inline filter. Besides, I know when I need to start looking for a fuel station without needing to switch to reserve. I'm anxious to get it and get it installed.
