November 19, 2025, 09:50:23 AM *
Author Topic: Centercover tab broke.....  (Read 3037 times)
bassman
« on: June 06, 2009, 11:36:14 AM »
Finally broke one of tabs on the centercover that holds the sidecover in place.....was able to salvage the tiny, tiny, teeny little nipple tab thingy and was wondering what is the current best / preferred method to secure it back in place?  JB Weld?  Super Glue? Tig Weld?  Spearmint gum?  OR??????   Undecided   Again, not the slot on the sidecover but the protruding whatchamacallit on the centercover.  uglystupid2
TIA !
« Reply #1 on: June 06, 2009, 01:12:26 PM »
Is it the bottom flat nipple looking one? If it is I don't think glue will work. This pc, at least on mine, takes alot of pressure, just as much as the slotted tab. Just use the 2 remaining tabs and see how it holds. It might just wobble but doubt it would come off. My slotted one broke and I held it on with a band aid for 1200 miles with no problems and there were 40 mph winds.
Master Blaster
Deridder, Louisiana
« Reply #2 on: June 06, 2009, 06:15:23 PM »
Ive repaired a few, made a replacement tab out of thin metal same width in an L shape.  After roughing up the inside of the center cover, used JB weld to attach the long side of the L to the inside of the center cover.  This way you dont screw the paint and mine have held for a few years with no problem.
« Reply #3 on: June 06, 2009, 06:30:35 PM »
Mine was broke when I bought the bike.  I just looked on ebay untill I found one.  It was still alot cheaper than buying a new one from Direct Line or Bike Bandit.
Warlock
Magnolia, Ms
« Reply #4 on: June 07, 2009, 04:13:55 AM »
TIA !
Go to Wally World and get you some velcro(sp). Put one piece on the side cover and the other on your center cover. Been running mine like that for 2 to 3 years now. I had broke my center tab also.
David
JimL
Naples,FL
« Reply #5 on: June 07, 2009, 07:12:02 AM »
After having bought 3 or 4 of these things over the past couple of years for my bikes, I decided a while back that I am going to go the route that Master Blaster described.  If care is taken you should be able to fabricate and attach a tab using JB Weld.
As a side note, mine have always broken when the temperature is below 40 degrees...I don't know if it is coincidence or if they are a bit less flexible and more brittle when the temps are lower.  At any rate, in my opinion this along with the  Petcock and Interstate inner fairing attachment is one of the biggest "faux pas" Honda committed on these great bikes.
« Last Edit: June 07, 2009, 07:29:10 AM by JimL » Logged
Motorider
Pennsylvania
« Reply #6 on: June 07, 2009, 05:06:34 PM »
JB weld is good stuff. I also like Quick Steel, it sets in five minutes, and can be found at most hardware stores and Wal-mart. It stays where you put it instead of running off to the lowest point. I used Quick steel to fix my side cover tab. I made a tab out of thin alumnium, drilled some small holes in the alumnium for the Quick steel to grab hold of and put it together . After the Quick steel cured, I used my dremel tool to shape the repair. Worked great.
bassman
« Reply #7 on: June 08, 2009, 11:56:34 AM »
Thanks guys....I like the "L-shape" option and will give it a try..... Grin
Skeeter (Va)
Virginia Beach, Va
« Reply #8 on: June 08, 2009, 02:49:56 PM »
TIA !
David
          Velcro worked fine for me, however, I went to Northern Supply (nationwide) and bought industrial velcro and it's a job to pull them apart....super strong stuff....been on there for years...
Life's tough....It's even tougher if you're stupid....        1998 Blk..Valk Std...1971 Honda 750 Four...
« Reply #9 on: June 08, 2009, 06:42:49 PM »
  "Go to Wally World and get you some velcro(sp). Put one piece on the side cover and the other on your center cover. Been running mine like that for 2 to 3 years now. I had broke my center tab also.
David"
Ditto on the velcro! cooldude cooldude cooldude Hoser
