February 05, 2026, 06:07:24 PM
Pre-ignition smell
Topic: Pre-ignition smell (Read 1373 times)
Frankie72
Pre-ignition smell
August 23, 2012, 05:41:28 PM »
My Valkyrie runs well, but I get that awful odor reminiscent of that pre-ignition odor from cars. I hope I'm using the term pre-ignition correctly. When you shut off a car, but the engine keeps puttering and won't shut off. The ensuing odor is the same odor I get from my Valk. Any suggestions?
Thanks!
John U.
Southern Delaware
Re: Pre-ignition smell
August 23, 2012, 07:32:12 PM »
I think the correct term for what you're describing when a car runs on after the ignition is off is dieseling. The smell is no doubt (regarding a dieseling car) incomplete combustion.
Why your Valk smells like that is certainly not from the same cause. Maybe a bad plug, bad plug wire or connection, a bad carb float, a dirty air filter, a pin hole in your petcock diaphragm allowing gas to run down the #6 vacume tube., pilot screws badly adjusted. There must be more possible causes but basically a miss or rich condition could be the culprit.
Last Edit: August 23, 2012, 07:33:58 PM by John U.
Michvalk
Remus, Mi
August 23, 2012, 07:37:43 PM »
Could also be the crappy gas we have to use nowadays
August 24, 2012, 04:51:30 AM »
I'm going to assume the engine shuts off when the key is turned and doesn't keep on running[ dieseling]..
So,, when do get the smell ?? While the engine is running or after the engine has stopped running/shut off ?? If it smells rich at idle,, thats normal..
Frankie72
August 24, 2012, 03:20:23 PM »
It smells during idling, such as at red lights. It shuts off fine.
Thanks.
valky1500
MI
August 24, 2012, 07:04:32 PM »
I dunno.
I get that roasted chicken smell from time to time.
It happens mostly when I'm going too fast.
'98 Standard
'01 IS
Yes I pull a trailer
I have taken notice to those who use that word (Precautionary) and abide by it are not only very happy in life...
but they also live long and prosper.
