February 05, 2026, 06:03:11 PM *
Author Topic: Re: Left rear bearing really toasted-NOW NEED REASSEMBLY ADVICE!  (Read 2488 times)
SpidyJ
Murrells Inlet
« on: August 25, 2012, 08:06:17 AM »
Ok, so the race is out after much spraying/heating and prying.  The bad bearing boogered about 1/2 the inside flat part of the wheel bearing pocket.  About 1/2 is smooth and flat for the new bearing to sit flush against once it's pressed in.
Will it be OK?  Am I taking a chance? Should I replace/repair the wheel?
Any tips folks?
All parts are on order so I have a week or so to deliberate?!
« Last Edit: August 26, 2012, 08:29:09 AM by SpidyJ » Logged
1999 Fast Black Interstate
Peace,
johnnywebb
Mr.BubblesVRCCDS0008
« Reply #1 on: August 25, 2012, 08:54:53 AM »
I would think it would be ok. My rear left bearing damaged my wheel some. I went to the bearing mod so now I shouldn't have a problem for a very long time
Madmike
Campbell River BC, Canada
« Reply #2 on: August 25, 2012, 02:47:27 PM »
if there is still parts of a good bore so that the two sides will align properly and you still have an inner seating surface for the bearing to seat against then there are lots of products available that you can use when you install the new bearing that will help restore some of the missing bore.  Take a look at Loc-Tite products, they offer lots of different products that may help you out. You can clean the bore with Aerosol Brake Parts Cleaner to remove any residual oil etc. if you want to use some form of anerobic material to help restore the bore area.
« Last Edit: August 25, 2012, 03:06:07 PM by Madmike » Logged
« Reply #3 on: August 25, 2012, 03:34:59 PM »
I'm not sure what you are trying to describe,, but,, if the bore is good and its the bore end that is damaged then it'll be ok if you make sure to install the bearing square.. Don't forget the spacer and drive or press on the outer portion of the bearing..
SpidyJ
Murrells Inlet
« Reply #4 on: August 25, 2012, 04:45:22 PM »
About 1/2/ the inner flat part of the bore is there  but the outer half of the  diameter  is boogered.
What products are out there that will restore the surface w/o welding and machining? Never heard of such a thing. Thanks for the help.  BTW I am doing the double roller upgrade..
Peace,
johnnywebb
art
Grants Pass,Or
Grants Pass,Or
« Reply #5 on: August 25, 2012, 05:53:34 PM »
Need pictures
« Reply #6 on: August 25, 2012, 07:24:35 PM »
Sounds like a new wheel to me.  I helped somone try to get one like yours to play nice and it was aggrivating.....new wheel, no more headache
Madmike
« Reply #7 on: August 25, 2012, 09:30:50 PM »
depends how much clearance you created.....
http://www.useloctite.com/filephotos/documents/Retaining_Solutions_Guide.pdf
SpidyJ
Murrells Inlet
« Reply #8 on: August 26, 2012, 05:51:42 AM »
So are new wheells readily available?
Thanks........
Peace,
johnnywebb
« Reply #9 on: August 26, 2012, 07:52:01 AM »
The real question is how well the bearing will fit into the cavity.
If the bearing installs properly and the only problem is the bottom of the bore where the bearing seats there should not be a problem. Especially so if there is only a partial degrading of the lip.
There is no applied pressure on the lip since the internal spacer is designed to receive the pressure of torquing the axle nut.
The main duty of the lip is to keep the wheel from being sloppy and stopping any axial movement of the wheel. Remember there is another lip under the bearing on the other side of the wheel which is complementary to the one that you are concerned with.
The important factor is the bearing bore which needs to be a very good fit with the bearing for safety reasons.
I'm sure there are still wheels available, maybe some new unused wheels and I've seen a few used wheels on EBay that are fairly expensive and those used wheels are not indicating the condition of the bearing bores which could in fact be the reason they are being offered for sale.
SpidyJ
Murrells Inlet
« Reply #10 on: August 26, 2012, 08:24:10 AM »
Need pictures
I have a nice photo....... :tickedoff:dang if I can figger how to upload it!
Peace,
johnnywebb
RP#62
Gilbert, AZ
« Reply #11 on: August 26, 2012, 08:33:41 AM »
Need pictures
You have to upload it to photobucket or one of the other picture sharing sites on the web.  That will give you a link you can then put in your post.
-RP
art
Grants Pass,Or
Grants Pass,Or
« Reply #12 on: August 26, 2012, 08:33:27 PM »
Need pictures
I know ,the whole process of posting pictures to this site sucks.It should be changed.I'm on some other web site forums and the posting of pic. is very easy
SpidyJ
Murrells Inlet
« Reply #13 on: September 04, 2012, 08:53:06 AM »
Parts all here.  Assembly commences.
 Undecided
Peace,
johnnywebb
« Reply #14 on: September 04, 2012, 10:26:30 AM »
Not so !!!  Posting pictures is easy.
It may not be as accommodating as you would wish it to be, but I am sure the way they do it on this forum is the most widely accepted method for posting pictures.
There are more concerns to it than just the ease of posting pictures. I am sure the security issues are more important.
« Reply #15 on: September 04, 2012, 10:49:14 AM »
Need pictures
Posting pictures on this site is only hard if you choose to believe its hard and dont try to learn.  As it has been said, get a free on line account to store your pictures then its just a cut and paste.........It's not hard to post raw mages from your camera, its impossible............
SpidyJ
Murrells Inlet
« Reply #16 on: September 04, 2012, 12:52:32 PM »
Need pictures
I know, it's Photobucket I had problems with.......I just haven't had the time and inclination to follow through with it.  Facebook has spoiled me with it's browse/upload/post feature.
Peace,
johnnywebb
« Reply #17 on: September 04, 2012, 01:00:19 PM »
Need pictures
Photobucket is the same brouse, upload then hover the mouse over the uploaded picture and you get a pop up...attempt to highlight the box that says "direct link" and it will change to "copied"  thats the copy....then paste in the center of the double brackets that appear when you click on the image icon of a post and yer done
SpidyJ
Murrells Inlet
« Reply #18 on: September 09, 2012, 05:52:37 AM »
Dang, forgot to order the 61mm "O" ring that goes around the wheel hub. 3-5 more days w/o the Valk and the weather is turning to beautiful!
Peace,
johnnywebb
