August 15, 2025, 06:15:57 PM *
Author Topic: New Battery defective  (Read 1215 times)
Roadog
« on: August 26, 2012, 01:29:21 PM »
  I bought a new Yuasa battery from the dealer last month (7/21/12) .   It has been turning over really fast and starting intstantly.  Well it stranded me at work last week, turned over noticably slower and then nothing not even a click.  Just like the key was off. Had to trailer it home.  Putting a battery charger on it,  it starts instantly as before but will not restart if charger is disconnected after engine is off.  Disconnecting charger and then turning engine off it will NOT restart. With charger it will restart good but without it will not , it pulls down to 6.69 volts under load while trying to start. Alternator is putting out 14.57 volts so that isnt the problem.  I installed the old battery that was turning over slow but will start bike and it starts good, just spins slow.  There is nothing pulling battery down  while off I checked for a drain there isnt one.  Everything checks out good.  Sure looks like a bad "new" battery to me.  Anyone ever encounter this ?  I guess you get a bad one sometimes.  First time the old girl EVER stranded me, it is a '98 tourer I bought new.  Going to dealer tomorrow with reeceipt and battery in hand.   It has one year waranty.
« Reply #1 on: August 26, 2012, 03:57:15 PM »
Who put the initial charge in the battery?
You or the dealer?
Keitho
Don't cry cause it's over Smile cause it happened
Ontario, Canada
« Reply #2 on: August 26, 2012, 04:20:16 PM »
I'm finding more & more lately that just because it's new, doesn't mean it's any good.
I wanna go with my boots on!
mmurffy03
03 standard
toms river new jersey
« Reply #3 on: August 26, 2012, 05:07:34 PM »
sears only gives you a 9 month return policy on there die hard gold battery
« Reply #4 on: August 26, 2012, 05:27:49 PM »
You or the dealer?
Good chance nobody did, R J, lot of folks don't know how important that is.  Hoser  Shocked
Roadog
« Reply #5 on: August 26, 2012, 05:53:18 PM »
  RJ..the dealer put the charge on the new battery , well..they said they did.  I went to pick it up and they said I had to come back 4 hours and it would be ready, so I assume they did.   It was good to find out it wasnt the bike but the battery, they are easy enough to install.  Dealing with a battery is nicer than a problem with the Valk.
donaldcc
Palm Desert, CA
« Reply #6 on: August 26, 2012, 08:30:13 PM »
  I have Yuasa, purchased at good price online a couple of years ago, poured the acid in myself, charged it myself.  Know it's done correctly.
  I'm not quite so anal with the whole process as this video but trust myself more than dealer or seller.
How to Fill and Charge Yuasa YTX14-BS Motorcycle Batterypowered by Aeva
Don
shooter64
« Reply #7 on: August 27, 2012, 02:42:03 PM »
Seems like if it will recharge from a battery charger to full strength, then the battery is good. Could it be that your alternator's charge is not getting to the battery properly? A bad battery will not charge up to full power any kind of way.
Columbia, S.C.
Roadog
« Reply #8 on: August 27, 2012, 05:04:26 PM »
  Hey shooter, I pulled out the new battery and  installed the old battery I replaced with new one  it starts just fine..spins  slow but starts and runs great.  Reinstalled new battery and nothing ..reinstalled old one and starts good, just turns over very slow but starts.  No it is battery issue for sure. Alternator puting out 14.59 volts, first thing I checked.  New battery would only start if a charger is hooked up , anyway..I have new battery and all is good.
sugerbear
wentzville mo
« Reply #9 on: August 27, 2012, 05:34:51 PM »
ding ding ding we have a winner!!
a 4 hour charge? every battery i've ever bought for a bike says 12 hours and a trickle charge. except for the gel cells.
bet they burnt it up.
