February 05, 2026, 06:07:24 PM
clutch tool help!!!
Topic: clutch tool help!!! (Read 1473 times)
shortleg
maryland
clutch tool help!!!
September 01, 2012, 03:03:29 PM »
What do you need to build a tool to take the clutch
basket apart.
BigBF is here and needs one to replace and repair one.
Shortleg[Dave]
WamegoRob
Wamego, KS
Re: clutch tool help!!!
September 01, 2012, 05:17:17 PM »
36mm or 1 13/16 socket, sawn in half with a 2" extension welded in:
tank_post142
south florida
September 01, 2012, 05:43:08 PM »
if you are talking about compressing the spring to pull the snap ring: i used a piece of thick walled pvc. just cut a 1-1/2 section out so you can reach in with the snap ring pliers. i just compressed it by setting it between my floor jack and the bumper on my van.
I got a rock
VRCCDS0246
BigBF
Text message at 602-332-4872
Phx AZ
September 01, 2012, 08:42:43 PM »
No worry... It's done remove snap ring off, we use C-clamps to compress and removed. But it did not do well. I'll have my wife send me the tool for it or I'll make one here I think I better make one and cheaper than have her mail it. So I can install back together without headaches.
pocobubba
Pocomoke , Md
September 02, 2012, 06:48:16 AM »
Seems like a big valve spring compressor would do the job .
BigBF
Phx AZ
September 05, 2012, 06:09:51 AM »
FYI: 36mm incorrect. Correct is 46mm.
