February 05, 2026, 06:07:23 PM *
Author Topic: |Need Help in SC ASAP  (Read 2443 times)
Red Diamond
Beaumont, Texas
« on: September 03, 2012, 01:02:49 PM »
My 2K Tourer will not start after shutting it off and the headlights are out. When i say will not start, I mean not even a click. All the other lights work just fine. I can push start it easily and it runs well, but without headlights. I installed the mini driving lights from walmart wired into the low beams. I,m in Richburg, SC, at the M6 motel. If you have any info aand would prefer to call me my number is
409 679-7520 Eli, AKA Red Diamond. Also, I have checked the fuses under the rt side cover, the 50amp fuse but can't think of anything else.
Thanks, Eli
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: September 03, 2012, 01:21:56 PM »
Sent you a pm, Eli.  It may be the starter switch if you didn't install a relay with the driving lights.
Take it apart carefully (small spring-loaded bits inside) and check for burned contacts.
The fact that you can push start it and still not have headlights might mean you have a blown fuse somewhere in the circuit.  I'd disconnect the driving lights and replace the fuse for the headlight circuit and see if that helps.
Check your headlight bulbs just in case.
It doesn't fit the headlight-out symptom, but a bad battery can happen suddenly and won't  turn the engine over even though lights seem to be fine.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Valker
Wahoo!!!!
Texas Panhandle
« Reply #2 on: September 03, 2012, 01:23:12 PM »
Yep-like other poster said-starter switch.
Valkpilot
Corinth, Texas
« Reply #3 on: September 03, 2012, 01:40:28 PM »
Also, since you said you tied into the low-beam circuit, you may have to check the Hi/Lo switch as well, depending on where you tied in.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Red Diamond
Beaumont, Texas
« Reply #4 on: September 03, 2012, 02:02:42 PM »
It is pouring down now, hopefully it stops before long, will get right on all suggestions, thanks for the responses.
Brian
Monroe, NC
« Reply #5 on: September 03, 2012, 04:14:00 PM »
So sorry you having issues while on the road. The weather is going to be horrible this week. Something you don't need hear right now. I assume you have checked to see where the Honda dealer is near you.  Do you have towing insurance?
Good luck tomorrow.
Red Diamond
Beaumont, Texas
« Reply #6 on: September 03, 2012, 04:22:08 PM »
Thanks ValkPilot, you nailed it, the starter switch loss contact. It was not fried, but was worn down where it would not function as it should have. I cleaned and lifted the little contacts on the push button and wham, she fired right up. I'll need a new switch though, as the button hangs little so I have pull it out sometimes. Also disconnected the lights until a relay is installed. Tomorrow, back to finishing the full usage of my kitchen pass.
Thanks again, Eli
Red Diamond
Beaumont, Texas
« Reply #7 on: September 03, 2012, 04:27:41 PM »
Good luck tomorrow.
Thanks Brian, the problem has been solved, yes I do have towing, she had performed flawlessly until that little hickup, the rain won't bother me now, I've been initiated.
dreamchaser
Portland, Oregon
« Reply #8 on: September 03, 2012, 05:02:34 PM »
I have a screw with a white plastic cover on it in the left side of my starter button.  It was there when I bought the bike.....I don't know why.  That would be good if you needed to pull the starter button out.  Maybe your scenario happened to the PO of my scoot?  Thanks for the insight into the history of my bike.  Congrats on your luck in rapid discovery.  This sight is great.
Jabba
VRCCDS0197
Greenwood Indiana
« Reply #9 on: September 04, 2012, 03:52:13 AM »
Just saw this... glad you're rolling Eli.
Good people here.
Be safe pal.
Jabba
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #10 on: September 04, 2012, 12:27:52 PM »
Have a brand new switch part # 35013-MZO-000 as a spare for my Standard and can ship anywhere along the road for you if you want. Just say the word pottsobviousdavid@gmail.com (remove the obvious)
Brian
Monroe, NC
« Reply #11 on: September 04, 2012, 04:33:37 PM »
Good luck tomorrow.
So glad to hear it was something you could handle on the road. Awesome people here. One member here even offering to send you his spare switch. What a great bunch of riders on this forum.
