February 05, 2026, 06:07:32 PM *
Author Topic: Learning Curve  (Read 1570 times)
miscott
Keep the rubber side down and hang on tight!
So. Central Kansas
« on: September 04, 2012, 02:36:36 PM »
 Hey all..
   Finally got the S.S. Hose Slinky on the `ol girl. I may have to shorten the slinky as it's quite a bit longer that the stock black one. Almost looks like a solid tube from the bottom hose mount to the top hose mount. It does look good! Will it hurt to leave it this way or should I shorten it to allow air flow through the slinky?
I'm not sure, but it seems like the airflow around/over the hose wouldn't make much of a difference.
  Took off the radiator cap to facilitate draining the coolant from the top radiator hose mount. Found out about the set screw after a lot of head scratching, wondering why it wasn't coming off!  tickedoff
  Of course, I found that I had a leak around the radiator cap after getting the cap back on and letting it idle till it was warmed up. Did a search of the tech board and found out about "bending the little tabs" to tighten up the cap seal. Worked like a charm! No more leak, and that S.S. Slinky looks a lot better than the stock black one!
  Now, I'm wondering, just what exactly is that set screw for, and would it be a bad idea to just leave it off? Wanting to find out before I put my cobra chrome radiator cap cover on and button up this job.
  I'm now out of aftermarket parts to put on the Valk, for now, so I guess I'll just have to force myself to go riding!  2funny
« Last Edit: September 04, 2012, 06:13:18 PM by miscott » Logged
PINSTRIPERART
I ride a 2000 valk tourer
san antonio
« Reply #1 on: September 04, 2012, 02:44:49 PM »
Keep the set screw, or the cap will vibrate off. Been there done that
9Ball
« Reply #2 on: September 04, 2012, 02:49:06 PM »
also, might stop someone with malicious intent from walking off with it....
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
miscott
So. Central Kansas
« Reply #3 on: September 04, 2012, 02:59:52 PM »
   Thanks! Hadn't thought of either of those thing!
miscott
So. Central Kansas
« Reply #4 on: September 04, 2012, 03:02:43 PM »
 Vibration? On a Valkyrie? Surely you jest, Sire!
« Reply #5 on: September 04, 2012, 05:27:43 PM »
DON'T tighten the set screw very much. It could dimple the radiator neck and cause the leak that yoou had. It's mearly meant to prevent unscrewing (is that possible?).
valky1500
MI
« Reply #6 on: September 04, 2012, 06:23:15 PM »
Not tightening any metric screw to snug and then 1/4 turn invites a non workable screw.
You can start planning on having fun trying to get it off if it doesn't fall off first. 2funny
'98 Standard
'01 IS
Yes I pull a trailer
I have taken notice to those who use that word (Precautionary) and abide by it are not only very happy in life...
but they also live long and prosper.  Wink
