February 05, 2026, 06:07:35 PM
Pinion gear needle bearings
Topic: Pinion gear needle bearings (Read 1228 times)
Sonny
Holt, Mo.
September 04, 2012, 09:00:47 PM »
I need to change this bearing. Has anyone done this? How do you get the bearing out? I have the pinion gear out but still need to get bearing out.
What a great day, lets ride!
1999 Valkyrie Standard
2003 VTX, 1800C
Re: Pinion gear needle bearings
September 05, 2012, 05:35:30 AM »
Haven't looked but COULD this procedure be covered in the Honda service manual OR on Dags downloadable manual?? Worth a shot.
RIDE SAFE.
lee
Northeast Tennessee
September 05, 2012, 06:21:22 AM »
Yes it can be taken out with patience and the right tools. Its a soft wire keeper. Take a large needle and
go down in the hold and turn the wire until you find the end. Then you need to pull up on the end and
get hold of it with a pair of real good needle nose pliers. Pull the wire out then you can pull the bearing out.
Time is not what is taken but what remains.
C. Drewry
