February 05, 2026, 06:03:09 PM *
Author Topic: Saddlebag mounting screws  (Read 1507 times)
mike4sho
Salinas, CA
« on: September 05, 2012, 03:20:04 PM »
Hello,
I recently got a set of interstate bags.  The bags came with the saddlebags, the mounting brackets and rear bracket.  However, no mounting screws.  I'm trying to make sure I have everything that I need when I order from HDL.  Can someone be so kind to double check I have the right screws?
http://www.hdlparts.com/fiche_section_detail.asp?section=2093218&category=Motorcycles&make=HONDA&year=2000&fveh=124340
Items; the (2) represents I need two of something - 44(2), 46(2), 47(2), 43(2), 58(2), 50(2), 4(2), 5(2), 51, 45(2)
I also picked up a trunk, and since I have a standard, I need to get the grab rails.  Do I need anything besides the grab rails or do they just mount straight to the fender?
Thanks for your help.
1997 Valkyrie<br />2003 VTX 1800c<br />2004 Valkyrie Rune<br />2009 Shadow Aero 750
« Reply #1 on: September 05, 2012, 05:15:05 PM »
Get Rattlebars bag drop kit instead of OEM bolts. It'll be much easier to remove the bags/brackets for rear wheel maintenance.
« Reply #2 on: September 05, 2012, 05:50:10 PM »
Rattlebars has been out of buisness for quite sometime now.   Sad
Robdawg13
« Reply #3 on: September 05, 2012, 06:12:38 PM »
Just went through this - I feel your pain!  The number required is the 2nd column on the parts list you posted.  You need 8 of the bolts that hold the bags to the brackets (# 58) and don't forget the "collars" (#4) - 8 of those also.  Rubber grommets (#5) were still on my bags, may want to double check so you don't order things you don't need - most Honda dealers will not return special order parts.  Good luck and congratulations on your new bags!
I don't want a pickle
I just want to ride my motor-sickle
mike4sho
Salinas, CA
« Reply #4 on: September 06, 2012, 05:44:16 AM »
Can't believe I missed that req # section.  Thanks for the post.  I'll double check the bags should make it a little easier and if I end up with a few extra screws, o well it's only a few bucks   tickedoff
Mike in AR
Redfield, Arkansas 72132
« Reply #5 on: September 06, 2012, 06:00:04 PM »
Is there anyone besides Rattlebars, that makes the bag drop kit? It would sure make things easier.
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
« Reply #6 on: September 07, 2012, 05:12:11 PM »
You can make your own with metric allthread and spacers/nuts from Ace Hardware. The allthread might be hard to find. You need 8mm X 1.25 pitch and 10mm X 1.25 pitch.
