February 05, 2026, 07:36:54 PM
kickstand
Topic: kickstand (Read 1498 times)
Firefighter
Harlingen, Texas
kickstand
September 16, 2012, 08:09:40 PM »
Hello everyone, I notice my 2000 Interstate wobbles on the side stand. When I put the kickstand down and put the bike weight on it. I also notice the stand has play at the pivot bolt. With the bike upright I can notice play ( I can reach down and move the stand up and down, in other words make the bike lean more and less). Other bikes I have owned have no wobble room. Is this play normal or is the bolt or bolt hole in the kickstand wore out? Worries me! Thanks. Also is any one having trouble with this website? I keep having to sign in and the site lets me look a while then doesn't know me again????
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
Re: kickstand
September 16, 2012, 10:34:45 PM »
Not normal. Crawl around with it up on a lift and check the bolt.
dreamchaser
Portland, Oregon
Re: kickstand
September 16, 2012, 10:47:23 PM »
Check the cross member of the frame that it's mounted to. It is the thinnest wall tube in the entire MC frame. The welding of this tube to the frame is often less than one would expect on so fine a machine.
N0tac0p
Re: kickstand
September 17, 2012, 05:24:33 AM »
i experienced the same thing, took everything off looked for wear, damage, etc. all items were to spec and lubed, so i cleaned relubed and put back on. yes it does wiggle and yes the bike when lowered onto the kick stand does slide a little lower due to this
