January 28, 2026, 09:40:57 PM
Seat release
Topic: Seat release (Read 2326 times)
Andy
Seat release
June 09, 2009, 07:31:25 PM »
My buddy asked for my help changing his air filter, no problem.
The seat lock wouldn't release. I know to push down on it as I have to do that on mine.
The key cylinder would not turn. I/we found a way to release the seat to do the filter change.
The lock mechanism will not turn at all. I traced the cable from the lock to the release and nothing is in a kink or bind.
Has anybody else experienced this at all???
I told him he's probably looking at a new seat lock mechanism or is there something we can do to remedy this?
Mr.BubblesVRCCDS0008
Re: Seat release
June 09, 2009, 07:55:13 PM »
cable probably needs lubing or replacing. You might try disconnecting cable to make sure the lock will operate.
Re: Seat release
June 09, 2009, 08:04:53 PM »
I had to spray my key cylinder with WD40 about 6 months ago as it was sticky and didn't want to move.
Or any good skunk pee, will work also.
Re: Seat release
June 09, 2009, 08:05:23 PM »
I second that most likely the cable disassemble lube and assemble happens quite a bit mine has been twice now.
clsimmonsjr
Re: Seat release
June 10, 2009, 04:52:59 AM »
Same problem here, I had to take mine to Goldwings of East Tennessee to get it off a couple of weeks ago. the mechanism had broke where the cable attaches. they ordered a whole new mechanism. I'm going to keep it lubed this time.
Baloo
Rimouski, Canada
Re: Seat release
June 10, 2009, 12:13:41 PM »
Got the same problem last year. I simply replaced the cable and the problem was cured. Once you get to the cable, considering the work to get there, you might as well replace it. Not expensive, just a few bucks...
Never ride any faster than your guardian angel can fly...
Andy
Re: Seat release
Reply #6 on:
June 10, 2009, 04:32:06 PM »
Thanks y'all!!
Raverez
No good deed goes unpunished
Central New York State
Re: Seat release
Reply #7 on:
June 11, 2009, 08:56:42 AM »
make sure the cable is properly in the clip on both ends. one at the lock the other on the frame.
