February 05, 2026, 09:18:31 PM *
Author Topic: carb sync  (Read 2178 times)
valk2000
columbus nebraska
« on: October 01, 2012, 04:37:51 PM »
How do you know if you need to get the carbs sync?
« Reply #1 on: October 01, 2012, 06:18:31 PM »
I don't think there is any sure fire method other than vacuum gauges to determine that.
There are several hints that signal a carburetor synchronization might be in order but there can be other reasons for the same symptoms.
It is easier to determine with a stock configured motorcycle as/when compared to a modified motorcycle.
« Reply #2 on: October 02, 2012, 07:14:21 AM »
Does this critter idle smoothly ?? When working the throttle easily does the engine speed increase smoothly and readily ??  If so,, everything would seem fine to me.. If not,, then a sync sure wouldn't hurt.. These carburetors are not known for going out of adjustment [ unless someone that doesn't know what they are doing has been screwing around with them].. Honda got this right and these are pretty bullet-proof..
CajunRider
Broussard, LA
« Reply #3 on: October 03, 2012, 05:02:19 PM »
Usually, it's good to sync after any air/fuel system alterations...
Muffler change, Valve Job, De-Smog, etc. etc. etc.
Other than that, sync 'em once and forget 'em.
Sent from my Apple IIe
valk2000
columbus nebraska
« Reply #4 on: October 05, 2012, 08:01:40 PM »
so what Im hearing if it run good and idles good, its OK.   This bike has only 9000 miles on it and never been touched   in any way
nerider2
Omaha, NE
« Reply #5 on: October 06, 2012, 11:28:26 AM »
It if is idling smooth, let it be.
2014 Daytona Blue Ultra Limited
2000 Stealth Interstate
1999 Excelsior-Henderson
Omaha, NE
VRCC #23874
Iron Butt Association #32532
john
tyler texas
« Reply #6 on: October 06, 2012, 06:01:04 PM »
          can you say  ....   cream puff            Smiley
  coolsmiley                  put some miles  on it ...
  if you have/find/discover  an issue                       Shocked
  address it        cooldude
vrcc # 19002
valk2000
columbus nebraska
« Reply #7 on: October 06, 2012, 07:47:06 PM »
  address it        cooldude
Its at a dealer to sell.  I happened to walk in .  someone was looking at it and said it needs a sync job I spoke up and said it got checked out when I bought it and it was OK.  Looker said well it doesnt sound like mine. I have no issue with it,  it gets up AND goes without a hiccup.
« Reply #8 on: October 07, 2012, 04:50:13 AM »
Well,, was the 'looker' there with his bike ?? It wouldn't hurt to compare ..
valk2000
columbus nebraska
« Reply #9 on: October 07, 2012, 04:59:47 PM »
no it was his wifes and they rode in with a V-star.   Was thinking about this today,  I wonder if it wasnt a ploy to get the $$$$$$ down.   Oh well time to move on.
