February 13, 2026, 04:07:00 PM *
Author Topic: replacing the indicator lights in light bucket.  (Read 1514 times)
ryord
« on: October 04, 2012, 07:39:49 AM »
I would like to put LED's in the 3 indicator lights in the light bucket. neutral light  high beam and signal, I have tried gently to pull them off but I need more instruction on just where to pull and how hard. Thanks
tank_post142
south florida
« Reply #1 on: October 04, 2012, 08:29:18 AM »
run a butter knife under the edge and give it a twist. they come out pretty easy.
I got a rock Sad
VRCCDS0246
« Reply #2 on: October 04, 2012, 08:49:36 AM »
Before you go any further, you might want to read this thread on installing leds in the indicator lights.
"Using A Rebel Indicator Harness to allow LED turn indicator on STD/TOURER"
http://www.valkyrieforum.com/bbs/index.php/topic,35394.0.html
Kep
My "Mid-life Crisis "
Indiana
« Reply #3 on: October 04, 2012, 11:33:22 AM »
Do the mod.Its easy , cheap and well worth it. Its one of the best mods. I have done to my Valk ! One tip though..keep the stock high beam lamp in but switch the Neutral and Turn signal indicators to high power LEDs. The HP LED is too bright for the High beam indicator if you have a windshield , it creates too much glare on your windshield when driving at night .Biggest benefit and safety factor is the extemely bright turn signal indicator with the HP LED !You definitely know that your signal is on !!!!!
D-Valk
« Reply #4 on: August 06, 2016, 10:25:29 AM »
So where do I find the LED bulbs to replace the original Valk indicator bulbs?
D-Valk
« Reply #5 on: August 27, 2017, 06:14:16 PM »
https://www.superbrightleds.com/moreinfo/instrument-cluster-gauge/24-led-bulb-1-smd-led-miniature-wedge-retrofit-car/229/1077/
