February 05, 2026, 10:55:45 PM *
Author Topic: new petcock??  (Read 2537 times)
mario
NW Houston, TX
« on: October 06, 2012, 04:45:42 PM »
so, i took the valk out today to 'air' her out.  i hadn't ridden her since inzane but i have started her up and put her in gear and such.  she starts up all the time just fine.
i realized after i got home that i rode for about 25 miles with the petcock on off.  i wasn't taking it easy on her neither.
question:  what's up with that and should i be looking into a pingle?
thanks ahead of time.
Mario
01 Valkyrie Standard (sold)
12 Suzuki V-Strom 1000
« Reply #1 on: October 06, 2012, 05:53:38 PM »
Its very easy to think the OEM petcock is off when it isn't.. The lever has to be set just right.. If that wasn't the case I'd say its time for a Pingle,, I'm not a big fan of the OEM valve.. Some will suggest that you rebuild what you have though..
john
tyler texas
« Reply #2 on: October 06, 2012, 05:54:08 PM »
                  coolsmiley                 its your money
   rebuilt kit under 20 bucks ....
then find someone (wrech party) that like to do the rebuild ...         Smiley    hummmmm
       worked for me ....    thank you again brother dave            cooldude
« Last Edit: October 06, 2012, 05:55:39 PM by john » Logged
vrcc # 19002
mario
NW Houston, TX
« Reply #3 on: October 06, 2012, 06:21:23 PM »
where do y'all purchase a pingle kit?
Mario
« Reply #4 on: October 06, 2012, 07:11:06 PM »
Since you have an OEM petcock you would buy a Honda rebuild kit for it. The Pingle is an aftermarket petcock.
My rides:
Red Diamond
Beaumont, Texas
« Reply #5 on: October 06, 2012, 08:25:36 PM »
Why would you even waste your money, just install the cover set as was mentioned. Nothing wrong with a stock petcock.
mario
NW Houston, TX
« Reply #6 on: October 06, 2012, 08:55:21 PM »
tj and i were just thinking the same thing, eli.  just to be clear, is this what i'm needing?
http://www.motosport.com/motorcycle/cart/
Mario
JaysGone
Delray Beach Florida
« Reply #7 on: October 07, 2012, 04:25:01 AM »
You need a empty cart???
Sorry thats all that shows.
Something more like this:
http://www.ebay.com/itm/Honda-GL1500-Valkyrie-petcock-rebuild-kit-97-04-/270741232316?pt=Motorcycles_Parts_Accessories&hash=item3f096f5abc&vxp=mtr
      1999 Valk - SOLD
      2005 Yamaha RoadStar
« Reply #8 on: October 07, 2012, 04:41:30 AM »
Here is one reason:
When I needed a cover set, I bought one, installed it and it worked great for a year or so, but there is no rebuild kit for the valve side of the petcock, that side wears out next and I was nearly stranded in the boonies on the way to Daytona.
At that point it was a new OEM or a Pingel (the Pingel was cheaper)
This is not a unique story...that OEM valve just isint up for the long haul IMHO (of course there are some that have lasted a long time)....but many that havent YMMV
Mr.BubblesVRCCDS0008
« Reply #9 on: October 07, 2012, 08:12:19 AM »
Made my stock one manual about 5 yrs ago still running it that way. on with the key off with the key.
Red Diamond
Beaumont, Texas
« Reply #10 on: October 07, 2012, 07:17:33 PM »
http://www.hdlparts.com/fiche_section_detail.asp?section=2136879&category=Motorcycles&make=HONDA&year=2000&fveh=124893
Try this Mary, #5 is the cover set.
art
Grants Pass,Or
Grants Pass,Or
« Reply #11 on: October 07, 2012, 09:10:44 PM »
same here ,about 50000 miles ago ,no more problems.I blocked off the vac end with a stainless plate and a gasket.cost $0
« Reply #12 on: October 07, 2012, 10:33:48 PM »
The rebuild kit (cover set) WILL NOT fix a problem of the "off" position not stopping fuel from flowing.
« Reply #13 on: October 08, 2012, 03:30:47 PM »
Mario, before you go to the expense and effort of rebuilding or replacing your petcock be sure you understand what Patrick was telling you.
It's likely your petcock wasn't turned off.
If you don't turn it so you fell it drop into the position for off it may appear to be off but not be.  It's not necessarily a problem with the petcock.  It's the position it which it was left.
It's also possible to tighten the screw that holds the handle to the petcock so that it binds and doesn't allow for the turn you need, especially if the petcock is not quite aligned properly.
Be sure of what your issue is before you embark on repairs.
mario
NW Houston, TX
« Reply #14 on: October 08, 2012, 04:19:27 PM »
got it, willow, thanks.  we'll talk more about it with the guru's  coolsmiley at the texas ride in this weekend, too.
Mario
Disco
Republic of Texas
« Reply #15 on: October 08, 2012, 05:05:38 PM »
Hey mario,
If you want me to, I'll bring a cover set, spare petcock, and pingel with me to Fredericksburg.  As I'm a fan of the oem petcock, I'm not sure the pingel is the one favored by most here (it came with all the goodies in the project bike haul).  My guess, based on year and assumed miles, is that if there is a component failure, it's the diaphragm.  If that's correct, the K&L kit available from the good folks at Old Bike Barn is all you need and it's about half the price of a cover set.  Might ought to order one anyway just to have in a saddlebag...
http://www.oldbikebarn.com/Honda-Petcock-Kit-GL1500-Valkyrie?sc=2&category=185
BTW, I'm sure this public posting is redundant to the private plans or current tool bag contents of others you'll be with in Fredericksburg...
« Last Edit: October 08, 2012, 05:08:24 PM by Disco » Logged
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
Joevalk
Santa Fe, Texas
« Reply #16 on: October 08, 2012, 06:38:28 PM »
Pingle! You don't need no Stinking Pingle!! uglystupid2
VRCC#32720
1999 Grn/Silver Interstate
mario
NW Houston, TX
« Reply #17 on: October 08, 2012, 06:48:00 PM »
joe! get back to the game!   Wink
Mario
mario
NW Houston, TX
« Reply #18 on: October 08, 2012, 06:54:55 PM »
Hey mario,
thanks for the info and offer disco.  don't bring the petcock supplies for me this weekend as i'll be riding the v-strom.
Mario
« Reply #19 on: October 09, 2012, 04:50:06 PM »
I was gonna say, I have a cover set in my tool bag all the time and we can replace it in Fred., but not I'd you're on the Strom.   Smiley
But then again, I have a dead blow hammer in there too.  Hehehe
Hay Cool
Joevalk
Santa Fe, Texas
« Reply #20 on: October 09, 2012, 05:09:14 PM »
5 & 0 Baby!!!!! Evil
VRCC#32720
mario
NW Houston, TX
« Reply #21 on: October 11, 2012, 08:14:24 PM »
One game at a time joe. Remember last years packers and how they imploded at the end.  Your guys need to stay healthy too. 'Lotta season left and I hope they do well.
Mario
