February 05, 2026, 10:55:19 PM *
Pages: 1 [2]   Go Down
Author Topic: I Put a Rear Tire on and  (Read 5120 times)
Rio Wil
« Reply #40 on: October 16, 2012, 08:07:30 AM »
If it's stripped as you report I think the big problem will be getting it out.
That is one item that only needs to be snug. There is no force on the threads.
A helicoil would be my choice of repair for that particular item.
Yeah....sometimes ya just go brain dead and crank too hard forgetting its aluminum!! I have to pull the final drive in a few weeks anyway to replace a worn pinion cup and drive shaft so will deal with it one way or another. That bolt has been in and out of its threads probably a dozen times over the years and that's a contributor
« Last Edit: October 16, 2012, 08:30:28 AM by Rio Wil » Logged
Rio Wil
« Reply #41 on: October 16, 2012, 08:21:26 AM »
As a spanner thwirler for a year or 2 there can be no harm in axle first and pumpkin nut last and seems a reasonable way of doing things.
The bit that gets me is how you can totally get rid of any signs of lube and get a lovely big mess of rust. Just because you may have a dodgy O ring or "misalignment" holding the O ring from sealing does not explain the amount of damage done  in relatively short periods of time in some of the pic's that have been posted.
Hot hubs going into deep water can draw in water (boat trailer bearings are classics for this) but a rain storm while riding barely cuts it, centrifugal force comes into play and throws water away from the seals.
No stirring, just an observation.
I run a Pirelli P4 on the rear (205-65-16) and the last one lasted 60 K miles.  I pulled the final drive for lube at 15-30-45 K miles. The drive splines and the pinion /drive shaft splines were perfect. At the 60 K check, the drive splines were still perfect, but the drive shaft/pinion splines were damn near gone, almost just a knife edge left of the splines. There was still adequate lube, and evidence that final drive lube was circulating as the two access holes were clear and unobstructed......so I am absolutely puzzled as to what went on and caused the self destruct.
Rio Wil
« Reply #42 on: October 16, 2012, 12:20:27 PM »
A couple of pic's:
Rio Wil
« Reply #43 on: October 16, 2012, 04:56:36 PM »
Dang.....I just noticed the date on the pic below is Aug 16 and I am now due a 5K oil change already.....two flipping months....where have I been??? 2funny 2funny 2funny crazy2
AHHHHHH, the Makers Mark is quite tasty tonight for some reason......
« Last Edit: October 16, 2012, 04:58:08 PM by Rio Wil » Logged
Oklahoma_Valk
Central OK
« Reply #44 on: October 17, 2012, 07:09:00 AM »
I bought makers for the first time yesterday. Its by far the best bourbon Ive ever had. Havent had many though. mostly just the ones found in every corner liquor store. makers is different though. So drinkable and flavorful. I love it!
-not to hijack the thread or anything hehehe
-cheers
Let those who ride decide.
Rio Wil
« Reply #45 on: October 17, 2012, 09:01:18 AM »
-cheers
As one Okie to another......cheers right back at'cha Smiley
I was born in Wilson, (about 100 miles south of OKC) and left OK at age 19.....great place to grow up....
indybobm
Franklin, Indiana VRCC # 5258
« Reply #46 on: October 17, 2012, 10:32:20 AM »
I believe the procedure in the manual is correct and necessary.
It is so easy to do it that way, why not just do it!
So many roads, so little time
VRCC # 5258
Pages: 1 [2]   Go Up
