February 05, 2026, 10:55:29 PM *
Author Topic: Advice needed on removing the center panel  (Read 1155 times)
Slvrvalk1
« on: October 22, 2012, 12:48:10 PM »
I am getting my Valk painted, and I have taken everything off except the center panel under the seat.  I know that you have to be careful with the bank angle sensor, but I could use some advice on how to get the center panel out.  I have the side bolts (the ones that go into the frame) out.  What should I do next?  I want to make sure that I am able to use the seat latch mechanism when I put it back together.
Any advice would be appreciated.
Thanks.
Dave
« Reply #1 on: October 22, 2012, 12:59:16 PM »
just unclip the lock and unscrew the bank angle sensor and then give it a good tug as it is stuck in a grommet at the bottom
Steve K (IA)
Cedar Rapids, Iowa
« Reply #2 on: October 23, 2012, 06:33:20 PM »
Pull upwards and forward.
States I Have Ridden In
« Reply #3 on: October 23, 2012, 06:39:23 PM »
This was my experience.
http://www.valkyrieforum.com/bbs/index.php/topic,38488.0.html
