February 05, 2026, 10:55:08 PM
Found Mystery Noise!
Topic: Found Mystery Noise! (Read 1587 times)
Dr Bobs Patient
Okatie, SC
October 23, 2012, 09:08:47 AM »
After owning the valk for 5 weeks, I have noticed a cicada (locust) type sound coming from the front end that I couldn't locate. This weekend I finished up my fork rebuild and when I went to reinstall the fender I noticed that some fabric/rubber mat on the inside of the fender was loose. Not knowing (or caring) what it was for, I just cut out the loose material and went on my merry way.
Well during the test ride I didn't hear that noise anymore. That material had been flapping in the breeze causing the sound like pinning a playing card on a back stay tube on a bicycle that hits the spokes!
Just thought I'd share. By the way, just what was that material under the fender for?
DBP
I keep doing that which I cannot do, in order that I may learn how to do it. - Pablo Picasso
Valker
Wahoo!!!!
Texas Panhandle
Re: Found Mystery Noise!
October 23, 2012, 09:19:17 AM »
Ironically, it's sound deadening.
October 23, 2012, 12:00:04 PM »
Had the same issue on mine. I elected to reglue mine. RIDE SAFE.
9Ball
October 23, 2012, 02:52:09 PM »
primarily noise reduction but they also help protect the inner fender should you run over and pick up a big rock, etc.
VRCC #6897, Joined May, 2000
1999 Standard
2007 Rocket 3
2005 VTX 1300S
Jabba
VRCCDS0197
Greenwood Indiana
October 24, 2012, 04:25:04 AM »
That mat is acne medicine. It helps prevent "pimples" on your fender.
Jabba
