August 20, 2025, 10:13:22 PM *
Author Topic: pilot adjusting  (Read 1843 times)
art
Grants Pass,Or
Grants Pass,Or
« on: June 12, 2009, 06:22:59 PM »
where can I buy a pilot adjusting tool.I had the carbs rejeted off the bike an I reinstaled them but I need to adjust the pilots while the bike is running.thanks. Art
gregc
Media Pa.
« Reply #1 on: June 12, 2009, 07:02:11 PM »
  Got mine from cycle gear,  was close to 100 dollars.    But don't know how you could do it , without the tool.
Doc Moose
VRCC#506 - VRCCDS#0002 - BOTS
« Reply #2 on: June 13, 2009, 05:24:48 AM »
You can make one out of brass tubing.  Fairly easy.  Sorry, don't know the diameter needed.  Anyone?
GW/Roadsmith Trike
Doc Moose
« Reply #3 on: June 13, 2009, 06:26:26 AM »
Okay, got off my dead arse and got the mics out.
I measured the brass tubing: approx. .220" OD and approx. .180" ID .  You then take a pair of needle nose pliers and insert it into the tube end, squeeze to make a flat section on the tubing so that it looks like a  " D ".  The tubing piece should be maybe 1 1/2" long, fashion a handle of some sort (I used a screw/nut combination) to the unflattened end and put a mark on it for reference when you start making the turns.
Don't over tighten the pilot screws when bottoming them, or it'll cost you!
GW/Roadsmith Trike
BonS
Blue Springs, MO
« Reply #4 on: June 13, 2009, 07:17:45 AM »
If you want an inexpensive factory made "D" you can get it here:
http://www.motionpro.com/motorcycle/partno/08-0242/
I just got mine and it fits. I'm going to Sears to pick up some of these:
http://www.sears.com/shc/s/p_10153_12605_00943401000P?vName=Tools&keyword=43401#descriptionAnchor
to help with turning the motionpro D tool.
Dave Weaver
Seymour, IN
« Reply #5 on: June 13, 2009, 07:18:09 AM »
Art,
  Here is what I and a lot of others use.  It is a bit that you can place in a socket. Also, go to tech board and search Motion Pro and read posts about adjusting pilots.  Good Luck.
Do unto others as you would have them do unto you.
BonS
Blue Springs, MO
« Reply #6 on: June 13, 2009, 07:22:27 AM »
Art,
We think alike. If you're feeling really flu$h you can match it with:
http://www.motionpro.com/motorcycle/partno/08-0229
art
Grants Pass,Or
Grants Pass,Or
« Reply #7 on: June 13, 2009, 01:04:43 PM »
thanks a lot I ordered the tool from motion pro. now I will be able to adjust an sync the carbs since I just got my vac. gages from harbor freight.This is a update on a help posting a while back on misfiring with my valk.While I'm at it I have some info for anybody in so.cal. on june 20 my son who owns doug douglas motorcycles in san bernardino at 24769 5th st is having a unvaling of the new triumph 1600cc  on june 20th for anybody interested.I cannot go since I live in Or. an just got called back to work in the machine shop after being laidoff in Feb. with a $5 hour raise .an offer that I cannot refuse. Thanks again Art
« Reply #8 on: June 13, 2009, 04:17:17 PM »
Pilot adjusting?  Evil
Michael K (Az.)
Glendale, AZ
« Reply #9 on: June 13, 2009, 04:54:26 PM »
OH-oh! Connie, you're gonna be in troouuble! 2funny
RoboCop
Rose City OREGON
« Reply #10 on: June 13, 2009, 10:04:04 PM »
that's how us cheapskates do it, a piece of radio antenna and pliers and presto
