January 28, 2026, 09:40:22 PM *
Author Topic: Turn Signal Problem  (Read 2148 times)
Merle
« on: June 12, 2009, 07:49:19 PM »
My left turn signal stays on.... checked the bulbs and they are ok.  any ideas?
« Reply #1 on: June 12, 2009, 09:12:54 PM »
I'd guess the grease in the switch has hardened up. Open the Housing and spray some brake cleaner in there. Move the switch back and forth and use a Q tip to clean it out. Relube the contacts and moving parts with a dielectric grease (Super Lube). It should be good for several more years.
godfire
Republic of Texas
« Reply #2 on: June 12, 2009, 09:44:27 PM »
Could  be that your flasher is shorted.
Ride Safe
Ride Often
« Reply #3 on: June 13, 2009, 03:03:17 AM »
Sounds also like you have lost the turn signal ground back under the right side cover, look in the black boot and find the green wire.
Make sure the connection has a good connection.  It has a tendency to work loose.
Merle
« Reply #4 on: June 13, 2009, 07:33:01 AM »
Hey guys, I found the loose wire... was in the headlight connection.  I did an upgrade to the cobra light bar and took the lead wire for the spots out of the headlight and added a fusebox back under the right side cover like kingbee.  I must have loosened one of the signal wires in the process.
thanks
« Reply #5 on: June 13, 2009, 05:05:35 PM »
Did you check your signal fluid level?   Cheesy
MP
North Dakota
« Reply #6 on: June 14, 2009, 05:07:34 AM »
Not only check the signal fluid level, but it does need changing. Be sure to use only full synthetic, DOT XXVII approved, or they will flash slow in cold weather. Roll Eyes
MP
"Ridin' with Cycho"
Merle
« Reply #7 on: June 14, 2009, 06:01:43 AM »
where is the dip stick for the signal fluid???  I think we have a couple extra right on this board.    2funny
