garyheskett All 49 x 3 st.louis
« on: October 30, 2012, 01:25:21 PM » |
Had a problem yesterday, bike started and ran fine in nuetral, as soon as you put it in gear, it died. This happened 4-5 times, then it wouldn't die when you put it in gear but when you tried to drive it, it was like the key was turned on and off constantly. I have a couple of questions. The Clymer manual (sidestand switch test, page 330) says put one lead on the yellow/black wire and the other lead on the green wire. With the sidestand lowered, there should be continuity. OK. First question, with the sidestand UP, I assume there should be NO continuity? I have continuity in both positions Next question, if I want to bypass the switch for the 2-3 weeks it takes to get a new switch from HDL, would I jump the green wire with the green/white wire? I assume the yellow/black wire is for when the sidestand is down, is that correct? Or, am I assuming its the kickstand switch and it may be something else? Need help, I'm electrically impaired. Thanks, Gary
« Reply #1 on: October 30, 2012, 02:22:23 PM » |
« Last Edit: October 31, 2012, 04:49:26 PM by Smokinjoe-VRCCDS#0005 »
« Reply #2 on: October 30, 2012, 03:01:14 PM » |
Gary, you can get that switch from Service Honda in Indiana for just under $30. They're closer to you than HDL, good people to work with. Just ask them to check on availability when you order it, they can tell right then roughly how long it should take. http://www.servicehonda.com/parts.html
« Reply #3 on: October 30, 2012, 03:16:01 PM » |
 Look's to me like green/white to green, but I ain't no 'lectrician either!
« Reply #4 on: October 31, 2012, 01:42:53 PM » |
Well. I took the switch off of the kickstand, it was pretty bad looking with dirt, grime, grease, etc. Cleaned it good with spray cleaner, put dielectic grease on it, put it back together, everything runs fine for now. I hope it just needed the cleaning and will see how long it lasts. Thanks.
fantsybikr
« Reply #5 on: October 31, 2012, 02:15:11 PM » |
the picture of the Valk crashed is hard to look @..I hope guy is ok..but that kickstand switch is on there for a reason..don't leave home without it !
VRCCDS 0252 VRCC 26284 GWRRA 329832
Greg aka smoothrider ?
A,O,S, LET'S ROLL
CLINTON TENNESSEE
« Reply #6 on: November 04, 2012, 10:42:35 PM » |
soken Jo got the story wrong when I got the bike it had the switch removed and it was hanging under the bike, I found it and did not fix it! it got me on the dragon so don't remove any safety device on any thing!
''LIVE LONG AND PROSPER''
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #7 on: November 05, 2012, 03:50:46 AM » |
Good to see you here Greg
